Overheating, maybe water pump?
Posted: Mon Jan 28, 2013 9:59 pm
Hi,
I've got a bit of an issue with my 1996 406 2.0 GLX, and I was hoping for a bit of advice before I try and limp it down to the garage.
Basically around 2 weeks ago (when it was very cold, just before the snow) I got in it, started it up, and heard a loud grinding noise. The noise faded off after 10 seconds or so, so I left it idling for a bit, then decided I'd best take it around the block before trying to venture too far. I got about 1/4 mile before I noticed the temp guage was waaaay past the usual sitting-in-traffic-max and visibly still climbing, so I turned it around and headed home. I hit the hot air blower on 'eco' to max, but all I got was cold air. I made it back just after the 'STOP' dash light came on, and the temp gauge needle resting just short of the end of the scale.
Could this be caused by a faulty water pump? There is plenty of water in the system, although the anti freeze level was close to *ahem* non-existent, and I can't see any visible leaks. I no longer get any noise when starting it, though I'm reluctant to drive it too far for a more extensive test.
Any help would be appreciated.
