sbarnes
Posts: 6 Joined: Tue Dec 05, 2006 3:23 pm
Post
by sbarnes » Sun Dec 24, 2006 10:36 pm
Hi there,
Someone told me that they had to change the battery in their picasso, since then the engine is running much better (quieter, smoother, quicker etc) also the electric windows have re-learnt their best limits etc.
Can this be true? does this also apply to the 406? would disconnecting then reconnecting the battery force the gadgets and gizmos to 're-learn'?
Any help appreciated.
munfred
Posts: 155 Joined: Thu Jul 06, 2006 10:15 pm
Post
by munfred » Mon Dec 25, 2006 4:38 pm
windows will work better because there is more juice in the battery to power them. Especially when the engine is not on.
Disconnecting the battery for about 20minutes will soft reset the ecu back to the factory parimeters
PJ
Posts: 182 Joined: Wed Aug 03, 2005 11:34 pm
Post
by PJ » Tue Dec 26, 2006 12:12 am
When I got my 406 the windows travelled the full extent whenever I pressed the control.
After disconnecting the battery they reset, and now work according to pressure (ie. tap for short movement, hold for full extent).
chili
Posts: 186 Joined: Sat Aug 05, 2006 8:12 pm
Post
by chili » Tue Dec 26, 2006 10:42 am
if you disconnect the battery will it effect the radio ? ie mine is mapped to my car
PJ
Post
by PJ » Tue Dec 26, 2006 10:53 am
I got away with re-entering the radio code. Can't say if this is the norm.
