Vibration at idle and grumbly on acceleration
Posted: Mon Jun 11, 2012 8:21 pm
Back again - I always say thanks on here because (most) of the info is spot on (especially Jasper - top bloke)
Right - I might have buggered up big style somewhere....
Driver side spring went and took out the CV joint... fixed the spring as per instructions on here... Purchased a 'brand new' cv joint from fleabay - £25 with abs ring - also changed drop link, bottom hub ball joint (yes, tapped lip over and purchased the tool with the teeth), track rod end (measured and put back same thread spacing), intermediate bearing, lower rear mount, oil seal and gearbox oil.. was a bugger but got it done - good stuff, well done, pat meself on back.. took it for a drive -
Gear selection hard - bled the clutch using one of those eazibleed jobbos fixed to tyre, went for another wee spin - still hard to select gears - checked gearbox oil - bloody 85/90 not 75/80... got proper job, drained and refilled.. works lot better, no issues selecting gear now... checked receipts that came with car - clutch conversion from DMF to solid in 2006... so....
Driving to work over last week noticed distinct vibration through steering wheel especially in neutral, press brake peddal lessens but doesn't stop it, turn steering wheel makes it worse.. had replacement tensioners (both) and lower pulley 6 months ago.. to be honest sounds like a hole in the exhaust noise - you know, that deep grumble, but stuck rags in end box and no leaks...
Engine still motors through gears, picks up fine when putting boot down, up and down gears rev counter matches speed, will tonk along at 90 on M1... However, has a tinny/rattly noise from gearbox area, makes no difference if I push clutch (which I still think feels softer than before these bits were changed).. no leak from gearbox...
I'm wondering if:
1. I buggered the inner CV joint getting the driveshaft off (I'm sure it was harder to get the shaft back into the hub, seemed too long but was ok if I shoved wheel half of shaft towards inner CV)
2. The outer CV is buggered 'cos it was a cheapo fleabay one
3. I MIGHT have lost one of the intermediate bearing bolts
4. I torqued the lower ball joint as much as I could with added breaker bar, could this be the issue
5. I jiggered the gearbox
6. The clutch needs re-bleeding using the old fashioned pushing of the peddal instead of the eazibleed (yes, I tipped it up drivers side high before I did it)
7. The top/gearbox mounts are shot (motor seems to be going front to back even though new lower engine mount fitted)
Question is... can any, none or all of these cause the vibration at tickover?
Cheers in advance
Gaz
I'm wondering if:
Cheers in advance
Gaz
