Page 1 of 4
engine won'tstart
Posted: Sat Jun 09, 2012 1:45 pm
by norrie499
Hi Lads
A couple of days ago the alternator belt snapped and i drove about six miles before i found a lay-by to pull into then got recovery home .Having replaced the alternator belt the problem i now have is that the engine is turning sluggishly and won't start .I've tried using a booster pack and a mate has tried slave starting it all to no avail. Ive had the battery on charge all night and it's still the same.The car is a Yreg 406 estate2ltr hdi
Re: engine won'tstart
Posted: Sat Jun 09, 2012 2:49 pm
by Doggy
Did the car drive OK between the belt snapping and you stopping, (apart from not charging and heavy steering).
Was the old belt tangled up around the crank pulley at all?
Posted: Sat Jun 09, 2012 3:14 pm
by norrie499
Hi Mate
the car drove fine until i stopped and there was no sign of the belt anywhere
Posted: Sat Jun 09, 2012 3:42 pm
by Doggy
It's possible for a damaged aux drive belt to get caught in the timing belt and cause all sorts of mayhem. Yours is probably OK, just odd that it doesn't want to start / turn over quickly. Maybe coincidence, but I'd be tempted to inspect the cambelt and check the timing, just to be sure.
Posted: Sat Jun 09, 2012 3:47 pm
by norrie499
Hi Doggy
I've got a mate coming to try and start it so will tell him what you say and will let you know how i get on .Thanks for the advise. :roll:
Posted: Sat Jun 09, 2012 4:13 pm
by lozz
Take aux belt off,
turn crankshaft pulley see if alls free,
start engine if it fires up,
it couid be :
belt was fitted incorrectly:
Wrong belt:
Somethings seized / pulley, air compressor etc, check each one,
Posted: Sat Jun 09, 2012 5:18 pm
by Doggy
Good thinking lozz, (suspect you had less beer than me, last night), Image
Posted: Sat Jun 09, 2012 5:45 pm
by Harshan
Lozz would be correct. This once happened to my old D8 due to a siezed alternator.
Probably the belt had snapped also due to the same awkwardness of one of pulleys
Posted: Sat Jun 09, 2012 8:27 pm
by lozz
Doggy wrote:Good thinking lozz, (suspect you had less beer than me, last night), Image
yeah true,
idont drink mate, havnt touched a drop in years,
Posted: Sun Jun 10, 2012 8:45 pm
by norrie499
Hi Lads
Up till now I've took aux belt off and checked all the pulleys and they're all spinning freely . Ive also taken the timing belt covers off and everything seems OK.My mate is coming tomorrow to check timing .I did find some strips ofbelt at the rear of the enginebut nothing in the timing belt even with everything off it still sluggish turning :cry:
Posted: Sun Jun 10, 2012 9:00 pm
by lozz
Battery ok mate?
you say you drove it 6 miles with no aux belt so the battery wouid of got some draining there no doubt,
Posted: Mon Jun 11, 2012 9:51 am
by norrie499
Hi Lozz
I've tried it with a fully charged spare battery ,also tried jumping it with my mates car
Cheers Norrie :(
Posted: Mon Jun 11, 2012 11:57 am
by Karl
The snapped belt could have hit and damaged some wiring preventing the car from starting.
Posted: Mon Jun 11, 2012 12:05 pm
by Ares
Maybe i dont understand english so well,but,did you tried to replace the alternator?
Could be the brushes are worn out.
Posted: Mon Jun 11, 2012 12:18 pm
by jasper5
I would be checking the starter motor.
