Water leak.
Posted: Thu Mar 08, 2012 9:25 am
by Tom
I've got a 2000 hdi and water is leaking from the narrow pipe that runs from header tank to thermostat housing. Took pipe off at thermostat end and steel pipe that comes out of housing has corroded. Has anyone had this problem and is there an easy fix? Thanks in advance.
Re: Water leak.
Posted: Thu Mar 08, 2012 2:46 pm
by omega
best way would be to replace the thermostat housing.
you could try bodging it by drilling the outlet pipe out then replaceing with a bit of pipe and arlditing it in.
Re: Water leak.
Posted: Thu Mar 08, 2012 3:42 pm
by Tom
Priced new housing. Over £400. :shock: I only paid £800 for car.
Re: Water leak.
Posted: Thu Mar 08, 2012 4:35 pm
by omega
Tom wrote:Priced new housing. Over £400. :shock: .
that cant be right are you sure its not 40 pounds.
someone with service box will be along soon to check it
Re: Water leak.
Posted: Thu Mar 08, 2012 5:23 pm
by Tom
Rang two different dealers and that's the price they both quoted. Couldn't believe it themselves.
Re: Water leak.
Posted: Thu Mar 08, 2012 6:47 pm
by dummysock
looks like its one complete piece.
Try some radweld
Re: Water leak.
Posted: Sun Mar 11, 2012 3:21 pm
by Tom
Decided to drill the old one out and araldite new tube in.
8mm drill and managed to do it in situ. So far no leaks and it only cost me £12. :)
