Water from the exhaust
Posted: Wed Feb 29, 2012 2:42 pm
by leestudd30
Is it normal for a small amount to come from the exhaust?
Re: Water from the exhaust
Posted: Wed Feb 29, 2012 2:45 pm
by lozz
leestudd30 wrote:Is it normal for a small amount to come from the exhaust?
Normal that for petrols,
Posted: Wed Feb 29, 2012 2:48 pm
by leestudd30
Really? I thought it was something to do with a car being used for lots of small journeys and it not warming up properly?
Posted: Wed Feb 29, 2012 2:57 pm
by lozz
Anything petrol with a cat-alystic convertor does it as a rule,
ive not seen many Modern petrol cars not, spit out the odd drip
Posted: Wed Feb 29, 2012 4:29 pm
by Gary406
my mate once had a vauxhall cavalier 2.0 16v and that use to pump water out the exhaust.
normal . means cat convertor doing its job properly .
Posted: Wed Feb 29, 2012 5:33 pm
by dummysock
When you burn any hydrocarbon fuel, you produce carbon dioxide, carbon monoxide and water ( normally as a gas i.e. steam )
If it comes out of the exhaust as water, then it's cooling down and condensing.
Posted: Wed Feb 29, 2012 5:36 pm
by Doggy
Roughly 1 gallon of water, for each galon of petrol.....
:shock: welly could start a flood all by himself!
Posted: Wed Feb 29, 2012 8:00 pm
Worse in cold weather when the exhaust is cold & the water condenses more quiclkier.
Not a problem. Unless it's disappearing from the engine....
Posted: Thu Mar 01, 2012 7:19 am
Doggy wrote:welly could start a flood all by himself!
When it rains in Northampton you have me to thank, next time taste a drop......it'll have 'notes' of Super Unleaded and Fully Synthetic Castrol oil 8)
Posted: Thu Mar 01, 2012 1:13 pm
by Doggy
So that's why Carlsberg has tasted even worse in the last couple of years. :roll:
