D8 1.9td LX Cam Belt Change
Posted: Fri Jan 20, 2012 1:21 pm
by gumby6371
Can someone confirm whether or not there is a cam belt kit for the 1.9td LX or is it just a belt?
I just called in at a local garage for a quote on a cam belt change and auto data said there were no tensioners etc to change just the belt, is that right?
After checking the history on my new car the cambelt is less than 10,000 miles old but as the previous owner was putting stupidly low mileage on it that could have been 9 or 10 years ago!!!!
Re: D8 1.9td LX Cam Belt Change
Posted: Fri Jan 20, 2012 4:10 pm
by jasper5
I recently changed the timing belt kit for Gary406.
There is a tensioner, guide roller and belt in the kit.
Changing the tensioner is quite a git of a job as you have to remove the engine mounting bracket that bolts onto the engine....the bracket bolts are also some of the tensioner mounting bolts.
Posted: Fri Jan 20, 2012 4:16 pm
by gumby6371
Thanks jasper, clearly I wont be using that garage :D
Posted: Fri Jan 20, 2012 5:32 pm
by Gary406
definately change the whole lot. when jasper removed my tensioner and guide roller . there was a lot of play in both clearly not good to put a new belt on old tensioners and guide rollers..
Posted: Sat Jan 21, 2012 12:12 am
by midsmike
hi mate get a gates kit i always use them and car spares do them if u lived closer i would have offered to do it for you and 1 more thing change the water pump to as the tension of the new belt can take the water pump bearing out
Posted: Tue Jan 24, 2012 4:07 pm
by gumby6371
thanks for the offer Mike, you're not that far away so be careful what you offer :D
I'll be doing it myself while my mechanic mate laughs and points at my spanner skills.
I only asked at the garage as they're walking distance from work and it would mean sitting in a warm dry office instead of scraping my knuckles in the cold and damp, but as he seemed to think it was just a belt to change I'd rather do it myself and know the full kit, water pump and aux belt had been changed.
