Hi,
Planning to do the fuel filter on the next service.
Which type do i have and any problems. Is the rusting around the side to worry about?
http://www.flickr.com/photos/74171186@N ... hotostream
Any info/advice appreciated.
Kind regards,
Ed
Name that fuel filter...
Peugeot 406 2.0 HDI (110bhp) Estate
Laquer free blue
2000 year car
normally 58.9MPG but 63MPG if solely for work run.
Laquer free blue
2000 year car
- 2.2 16v
Re: Name that fuel filter...
Does it have a priming bulb? If yes,then its a siemens,if not its a bosch
Rusts nowt to worry about. Just give it a clean up
Normal advice here is to buy the whole assembly - the filter cartridge AND the housing as they're a pig to open and risk getting bits into the unfiltered side.
Everything must be clean around the work area, the HP pump is very sensitive to dirt. They used to say that the filter should be changed in a clean environment (makeshift tent, disposable overalls, hairnet
) but most just take their time and keep it clean - hence the new housing helps etc.
- plod
Same as mine - £54 from GSF when I had mine - Bosch IIRC
1999 D8.5 HDi GLX - Sold
Bring back my 406
cheers guys...
Laquer free blue
2000 year car
Laquer free blue
2000 year car
- 2.2 16v
Get 1 out scrappy. Should get it for tenner. I need a new 1 as well
How often do they need changing?
once a year would be good. my mate often fills drums up with diesel from the pump.
you wouldnt think there was so much sh*t in pump diesel. every drum is full of crap at the bottom. so i change my fuel filter every 6 months, mind you its ok cos my fuel filter only cost's £3
