i have finally managed to get the cooler pipe off my recovered/abandoned 406 (see my thread in the electrical section) and it transpires the car has had a small bump at the front - pushing the cooler pipe inwards and upwards onto one of the radiator fans.
This means it then sliced a huge gash in the pipe in the process - now im living in the outback of australia so getting a new/used part is going to be difficult and certainly will take a while, so anyone have any suggestions on any diy repairs i could attempt in the meantime ?
i am on the lookout for some hydraulic pipe and have some clamps so was going to attempt using those ?
power steering cooler
Re: power steering cooler
craiggc wrote:i have finally managed to get the cooler pipe off my recovered/abandoned 406 (see my thread in the electrical section) and it transpires the car has had a small bump at the front - pushing the cooler pipe inwards and upwards onto one of the radiator fans.
Hi Craig, Is the cooler pipe the one that coils around under the radiator and about 10mm diameter?
If so I have one of these that I repaired in my garage at home, I used a piece of high pressure brake servo piping and jubilee clips....it isn't under pressure so any oil/fuel resistant piping will be fine.
I'll try to post a picture for you sometime today.
Here is the photo....
http://s638.photobucket.com/albums/uu10 ... 24x470.jpg
The pipe is more like 12mm internal diameter than 10mm.
- 1.6 8v
yeah thats the one - glad to hear you have repaired using the method i was going to attempt.
looks like the same thing happened to you ?? - its a failiure waiting to happen having the pipe in that location
there must be some pipe somewhere round these parts !
craiggc wrote:yeah thats the one - glad to hear you have repaired using the method i was going to attempt.
looks like the same thing happened to you ?? - its a failiure waiting to happen having the pipe in that location![]()
Yes, it's a common problem, I've replaced quite a few, the location is definitely poor.
I repaired this for a customer as a temporary repair until his new part arrived...I keep it in case someone else needs one in a hurry.
Pity you aren't a bit closer, you would be welcome to it.
- 1.6 8v
Re: power steering cooler - FIXED
blagged a length of pipe and fitted it xmas day - popped fluid in it yesterday and the car now drives like a hovercraft not a sherman tank.
thanks all for the info !
