cat removal ???????????
Posted: Mon Nov 21, 2011 4:32 pm
by craigtd
hi
can anyone help please,im going to start rebuilding my 2.0i turbo 406 soon but i know it needs a new cat :cry: does anyone know if i can do away with it and put a cat replacement pipe on ? its on a R.reg,
Re: cat removal ???????????
Posted: Mon Nov 21, 2011 8:31 pm
by 406loon
2 options:- 1. Either gut the cat (remove it and drill out internals then refit) or 2. replace it with a 100 cell sports cat. You will need the appearence of a cat or a sports cat for 2012's mot purposes.
Posted: Mon Nov 21, 2011 10:06 pm
by Doggy
Will it not be impossible to pass the emissions test without a functioning cat on any post 1992 petrol engined car?
Posted: Tue Nov 22, 2011 9:32 am
by highlander
If it's a petrol-engined car it is very unlikely to pass the MOT without a CAT being fitted.
Sports cat would be good here, shouldn't be difficult to fit - I don't think D8s had any pre-cat/post-cat sensors. When I was in getting the Powerflow exhaust fitted to my Coupe I asked the guy about sports cats; he said for a naturally-aspirated car there's not a whole lot of point, but they'd be most concerned about the sensor(s) that is/are present around the factory-fitted cat.
With a D8 turbo petrol, not only would it be easy for an exhaust place to fit one, you might notice it being an improvement as a sports cat will be freer-flowing.
That said, I reckon you'd be best getting an original cat for this car; take one from a scrappy. It's an R-reg petrol-engined French saloon car with a lazy 8-valve engine with a low-pressure turbo fitted to it; a new cat (OEM or after-market sports cat) will cost you just as much as (if not more than) the car is actually worth.
If you do want to go ahead with a major (expensive) overhaul of your car, then I would recommend replacing the entire exhaust system from manifold to exhaust tip with a custom-designed Powerflow system. It will cost you a fair chunk of money (my cat-back system was £360 all-inclusive) but it will allow that engine to ditch its exhaust gas much more quickly, and it will never rust.
Posted: Tue Nov 22, 2011 9:53 am
What make of exhaust was that again? :P
I think that's the bottom line, any car manufactured after August 1992 (which is all 406s) will need some form of cat. The diesels should hopefully get past with a hollow tube but I really don't think it'll wash on a petrol.
Posted: Tue Nov 22, 2011 10:00 am
by highlander
Powerflow!* :cheesy:
The reason diesels get away without a cat is down to the way the emissions test for diesels is performed in the UK (or possibly more accurately, the way that it isn't).
Petrol-engined cars have to pass a fairly stringent test, whereas the diesels basically don't have to worry about it (and some get away with murder, really, the amount of crap I see coming out of some diesel-powered cars). It won't be long before that changes, I reckon.
* other exhaust brands are available
Posted: Tue Nov 22, 2011 10:19 am
by TRAVIS BICKLE
I tried the downpipe / cat on project xsara 8VT and realised I had to cut it up to get it to fit, in the end I just cut the flange off and made my own decat pipe. Though I will have to fork out a couple of hundred for a sports cat come MOT time next July. At the moment the exhaust is a mix match of all sorts while I get it running.
I'll make a proper system up when I have more time.
Posted: Tue Nov 22, 2011 10:20 am
by craigtd
thanks for all the comments, ive found a new after market cat on ebay for £93.00 (item number 180549763420) so i think i will just go for this as the rest of the system is brand new and standard. :)
Posted: Tue Nov 22, 2011 12:51 pm
by Doggy
A cheaper option than a 'sports cat' would be an ordinary one, from a bigger-engined car. [/2p worth]
Posted: Tue Nov 22, 2011 9:14 pm
by 406loon
It is possible that some cars can pass an mot with a gutted cat.
Posted: Tue Nov 22, 2011 11:10 pm
by Doggy
406loon wrote:It is possible that some cars can pass an mot with a gutted cat.
I did wonder about that, as my old 24V Carlton almost met the emissions limits for a post '92 car after removing the cat. (It was a '91 so didn't have to comply).
Posted: Wed Nov 23, 2011 7:42 am
I wonder though if you fit a bigger CAT from a bigger car then it would take too long (or won't) heat up properly and still fail the MOT? [/2.4p inc vat]
Posted: Wed Nov 23, 2011 10:11 am
by mjb
Welly wrote:I wonder though if you fit a bigger CAT from a bigger car then it would take too long (or won't) heat up properly and still fail the MOT? [/2.4p inc vat]
The 406's V6 engine won't even pass its MOT using the standard cat unless the car's been idling for aaaaages. Damn things fail on it first time every bloody year :(
