Hi all, this last few days I have noticed that when I am driving along steady at any speed over 40 mph I notice the engine seems to be pulling back a bit. Not so much as missing more like you easing off then putting power on again. It is only for a second or so but it goes on every two or three seconds. When I put the revs on she pulls away ok but can be a bit hesitent sometimes.
The car is a 406 HDI deisel 2ltr and is a V reg. I have replaced the fuel filter, air filter but done nothing else. I have noticed what looks like a valve at the rear back left of engine bay with a small pipe laying next to it and when I plug it in the engine does not rev so just left that alone. Any help will be gratefully recieved.
Engine miss
Engine miss
2000 ltr LX Deisel HDI. Gold colour. Running with a Citreon Piccaso engine (52model)
Re: Engine miss
hi there mate
the valve you are looking at is a boost control valve i think, so if its faulty it will act like you are loosing power,ive come accross this alot when i worked for pug.
Re: Engine miss
Thanks craigtd. Have you any thoughts of the engine seeming to pull back a bit. When running along with a steady throttle it feels as if it is missing a bit. I have fitted a mass flow air meter a few months ago because of a lack of power but this fault is different to that. It is a little bit like on a petrol enging when you leave the choke on to long and the engine seems to choke off a bit.
Thanks for you reply.
