hdi 90- wont start
hdi 90- wont start
turns over but wont start.the display says "econemy mode active" so i ve tried jumping it and still no go.going to but the battery on charge to see if that cures it but if not how to you reset it.?
Re: hdi 90- wont start
If you can spell "economy" it brings up all sorts of stuff using search
Looks like a flat battery is favourite, so see what happens after a charge.
cheerssteve_earwig wrote:If you can spell "economy" it brings up all sorts of stuff using searchLooks like a flat battery is favourite, so see what happens after a charge.
its not ne its this conputar that cant spill.
What happened was I was lazy and used your spelling (text is a bit small from 10 feet away so I didn't spot it) and wondered why the only result I got was your post
- lozz
spelling dosent matter does it,
im a dyslexic %$&? so icarnt help it,
oh and have you seen this,
I cdnoult blveiee taht i cluod aulacity uesdnatnrd waht i was rdgnieg. The phaonmneal pweor of the hmuan mnid, aoccdrnig to rsceearch at Cmabrigde Uinervisy, it deosn’t mttaer in waht oredr the ltteers in a wrod are, the olny iprmoatnt tihng is taht the frist and lsat ltteer be in the rghit pclae.
The reset can be a taotl mses and you can sitll raed it wouthit a porbelm. tihs is bcuseae the huamn mnid deos not raed ervey lterter by istelf, but the wrod as a wlohe. Amzanig eh? And I awlyas tohghut slpeling was imporantt…! And for thsoe of you wtih mroe tmie tahn ohrets, you wlli ntocie taht not olny are msot of the wrosd a mses but smoe of tehm are cpmlpoetley msiseplt awslel…!
I couldn’t believe that I could actually understand what I was reading. The phenominal power of the human mind, according to research at Cambridge University, it doesn’t matter what order the letters in a word are, the only important thing is that the first and last letter be in the right place.
The rest can be a total mess and you can still read it without a problem. This is because the human mind does not read every letter by itself, but the word as a whole. Amazing, eh? And I always thought spelling was important! And for those of you with more time on your hands than others, you will notice that not only are most of the words a mess but some of them are completely misspelt as well!
I have actually. I couldn't figure ohrets out without reading the translation.
I don't really mind, so long as people at least try. What I do find hard is paragraphs written in txt spk containing no punctuation whatsoever. That really gets on my ttis.
- lozz
Yup, Iagree mate,
that Textin stuff, is abit anoying.
another thing that anoys me is when people, write a big Essay and theres No gaps/spaces
it plays havoc- on the eyes,
itry my best with spelling at times,but its hard
Dyslexia is not good, somedays ican spell ok
I can relate to that - I've no trouble spelling, but I've got numeric dyslexia, just copy a series of numbers and sometimes swap a few of them around, (as waue noticed when I made him 9 years younger).
First noticed it at school, around 1696
Anyways, did you get it started?
- lozz
Daft Question,
but is this the 90 Estate, that was advertised on the forum
with mention of H/g failure
yep thats the onelozz wrote:Daft Question,
think the head gasket is okay
no water in the oil
took round to a mates garage with sniff tester nothing in the header tank[but not 100 % as its not running]
got a good battery that i charged up overnight and still the economy light is on
going for another mess about now
all ideas welcome
This caught my eye - viewtopic.php?f=1&t=13807&p=126975&hili ... rt#p138227
Try a BSI reset? (You put your left leg in...)
had the connections under the carpet apart nice and clean and dry
so how do you try this bsi reset|?
done a search[cause i can spell bsi
] but cant find how to do it.
thanks againsteve_earwig wrote:Here it is viewtopic.php?f=10&t=10968&p=97438&hilit=reset#p97438
the good news
the fault light has now gone
the bad news
still wont start
off to church parade now will try again later
Maybe the ekonermie mode came up after loads of cranking and now you're back to the original fault
