cambelt kit
cambelt kit
I have a spare cambelt kit for my 2002 406 hdi110 and have just bought a 2000 hdi 90 306 which is due a cambelt change,are they the same kit for both or is the 110 different from the 90?
2012 "62" Yamaha XT1200
1974 "M" Honda CB500/4
1994 "M" Kawasaki Zephyr 1100
1998 "S" Honda XRV 750
Re: cambelt kit
And today's word is "probably"
I'm not sure what's in the kit (belt, tensioner, idlers, waterpump, crank sprocket?) so if you list the parts I can go off and check them on Service Box.
Re: cambelt kit
Cheers the kit has the belt,idler and tensioner in it.
Re: cambelt kit
I know for sure that there are 2 types of cambelt kit.
They have a different length of belt and a different tensioner.
I've been supplied the wrong one more than once.
Steve is the man though for expert servicebox advice...I can never fathom servicebox...it's my age you see
Re: cambelt kit
Piffle, it is confusing and you need OCD to work out how to use it - I'm in and out of it all the time but it still confuses me.
Like now for instance - it only lists 1 belt for all DW10s
Re: cambelt kit
This might be the problem:
0831 82 - MOTOR KIT (comprising roller, tension roller and belt) - UNTIL RPO No. 08735
0831 V3 - SINCE RPO No. 08736
The belts are the same but the rollers are both different.
The magic date is Tue 10 Oct 2000 (fingers crossed!)
Re: cambelt kit
The 306 was registered 22 Jun 2000 with a vin ending 08721,so what does it make it? Wrong knowing my luck.I bought the 306 of a mate who needed the space quickly as he had another car coming,he neglected to tell me that it had not had a cambelt change and it's done 75k and i had'nt factored a belt change into the deal,i only bought it to sell it on and make a buck or two but bang goes that theory!
Re: cambelt kit
Edit: I did write that the vin number isn't the same as the RPO but I just realised it's irrelevant because of the registration date
Edit edit: If it was registered in June it was definitely built before October.
75k is kind of in between - you should really change it, especially if you don't know how it's been driven or owt but it might last long enough for you to ebay your timing belt & pick up the right one. Also the HDis are designed to survive cambelt failure - you *should* just loose all the rockers.I wouldn't fancy this myself TBH but I have enough to worry about, without listening for my engine to go bang at the worst possible moment.
Re: cambelt kit
Perhaps it might just have a belt change then and not pulleys
