Gear box oil questions
Posted: Mon Nov 07, 2011 8:10 am
by no2lurch
What gear box oil do I need for my d9 2.2 petrol?
Is it easy to check/ top up?
Re: Gear box oil questions
Posted: Mon Nov 07, 2011 12:26 pm
by martint
why would you change gearbox oil? doesnt need changing the manufacturers say
Posted: Mon Nov 07, 2011 1:06 pm
by no2lurch
I didn't say I wanted to change it. I want to know what sort I need in case it needs topping up.
Posted: Mon Nov 07, 2011 1:37 pm
by jasper5
You need EP 75W80 gear oil.
Not sure where the level check is on your box (might not have one). You can fill it through the plastic breather on top of the gearbox or through the reverse light switch on top of the gearbox.
Posted: Mon Nov 07, 2011 1:49 pm
Is a 2.2 petrol a BE or an ML? I have a feeling it's a BE and no-one's ever given us any details on fillers or drains on one.
martint wrote:why would you change gearbox oil? doesnt need changing the manufacturers say
And you believe them?
First thing I did when I got my D9. Anyway, it's got no level plug so it was the only safe way of getting the level right.
Even if it's got a level plug it's probably worth just draining it out & filling it up with the required amount, that way you don't have to worry about getting it up in the air totally level.
Posted: Mon Nov 07, 2011 2:01 pm
Nah, it's an ML5T or C, go look at mjb's clutch how to.
