No start
Posted: Sun Oct 23, 2011 12:36 pm
by lecky4
Strange one this. Everything was OK until I replaced the rear right wheel. Now the engine just wont start. It did come of the trolley jack with a bit of a bump so was wandering if there's anything at the back which may have inhibited the fuel. The crash switch in the engine bay hasn't tripped. The only other thing is the car is very low on fuel but was running OK before so don't think that's it. Had a quick look for loose connections but nothing found, off now to look more in depth.
Re: No start
Posted: Fri Nov 04, 2011 10:52 pm
by craigtd
put some more fuel in, you havnt said if its a diesel or not but if it is it will have sucked up air from the tank so you will have to bleed the injectors off to get the fuel back up to the rail.
