Inlet manifold removal
After blanking off the EGR and seeing the shocking sight of the EGR pipe filled with thick oily sludge I have been thinking about getting the inlet manifold removed and cleaned out. Has anyone done this themselves and knows the work involved etc?
53' 406 2.2 HDi SE saloon - Samarkan Blue
Coupe strut brace-BMC CDA-Bosch Aero wipers-2.5'' T304 fap back exhaust-de-cat/dpf internals-EGR blank-180bhp remap-Ultra Racing rear lower brace-Poly engine mount- Brembo calipers-braided hoses-LEDs-55w Xenon 6k kit-nightbreaker plus main+fogs-LED sidelights
Re: Inlet manifold removal
Don't think you'll find anyone that's had a DW12 stripped down, there's so few of us and problems are few & far between.
No personal experience, but it looks fairly complex.
Do you really need to? (If it ain't broke, don't fix it).
you could try some Wynns EGR3, that supposed to do the job without stripping down, just remove the pipe between the manifold and the turbo. Some people get smoother response and better perfomance, I've tried it and all I have is a cleaned intake.
Hmmmm, straight 6 goodness!
