Car T-reg 2.0HDI 110
Read my faults the other day and these keep coming back.
With engine not running
Permanent fault circuit TL4226 faulty. Faulty circuit
With engine running
Permanent fault. Flowmeter signal. Open circuit or short circuit to earth
Intermittent fault. Circuit additional heating 1 open circuit or shot circuit to earth
Intermittent fault circuit tl4226 faulty. Faulty circuit
Dose anyone know if or how I should fix them.
Thanks in advance
2.0Hdi 110 Fault readings. Help Please
Re: 2.0Hdi 110 Fault readings. Help Please
TL4226: http://www.ilexa.co.uk/forum/index.php?topic=12032 - interesting stuff
I have the same problem. Did you found what was the problem. Car doesn't have power like before until 3000 rpm, after 3000 rpm it's accelerating well.
I say 'Holly thread resurrection Batman '
Seriously though the op hasn't been on the forum for over eight year's.
Yours sounds like a duff MAFF issue.
Hence the flowmeter comment in the old post & the glowplugs always throw up flaut codes ( unless your in -10° don't worry)
2006 BMW e61 535d m-sport
run's for cover
Failing MAF is likely - you can disconnect it and see if it improves ( lift the little tab on under the grey connector )
