Hi there
Got the antipollution fault warning, car wont rev past 2500rpm
this happened the other day and my mechanic mate said just sit and rev it til it clears the pipe. within minutes that had worked and all was well. however today the same thing happened again and it now wont budge
ideas?
Engine wont rev past 2500rpm (antipollution fault)
- sockpuppet
406 2.0 HDi Rapier, 2003 plate
- rwb
Re: Engine wont rev past 2500rpm (antipollution fault)
Unfortunately Engine anti-pollution system defective can mean almost anything. You need to get the fault code read to be more specific.
Last time I had it my mechanic read the fault code which identified the throttle potentiometer. He squirted some electrical grease onto it and cleared the code, and it been fine since (he didn't charge me).
- sockpuppet
something tells me ill struggle to find an open garage on boxing day!
its a problem on my friends 406, i mean to get over with my new pp2000 but havent done it yet, hope it gets the problem sorted, hes been driving in limp mode for about 2 months and says its 'dead easy on diesel' i said is it not a bit dead on the power.
