As above really, only started the other day, it's not too loud, just wondering if it's something to be worried about? The Car's done 145k, due a service sometime soon, bit of a oil weep on the sump nut (prob the copper washer?) Any help gratefully recieved.
Oh totally unrelated, but, Cheers Foxy, the leather's in and looking minty
D8 1.9 TD turbo Whistling
They call me Grand-Pa!
I posted about this ages ago, my turbo whistles a high pitch whistle, like you hear on a lorry going past.
Lower pitch whistles can be air leaks in the hoses etc.
It may be important to note that I cannot really hear the Turbo when the windows are shut.
My mileage is 107000, I was bothered about it once but the car pull like a train and it has not got any worse. Interestingly the whistle is more noticeable when engine cold, after a good run it is less so.
Diesels run higher boost that petrols and you allways seem to be able to hear a Diesel Turbo over a petrol one.
I'd agree with Welton. My HDi turbo can be heard with the windowd down, but with the windows up you'd need both the stereo and the aircon fan off before you'd hear it, and then only just.
BTW, my new stainless mesh filter whistles like i've got a jet engine bolted under the bonnet, and when you lift off between changes it chuffs in a similar manner to a dump valve, though not so loud. sweet
