98 V6 saloon
Posted: Thu Apr 29, 2010 3:41 pm
realised it had wrong battery on it when come december it was sat outside house because i couldnt afford all the work needed doing for mot. gets in her to start getting some of the work done dead as a dodo ignition lights dimm as hell not even enough juice to turn over she just clicked tried overnight recharge on battery puts it back in next day same again. replaced battery , it looked like a micra battery!! re prog key to car and c/locking fine, then gets her through mot march and back on road for a month and other day was working on delivery using car gets back in , bearing in mind i'd only turned her off less than 5 mins previous, turns key all lights up fine turns again to fire her up nothing and i mean nothing not so much as a click or beep. gets out pops bonnet made sure i couldnt find any loose wires or obvious stuff, checks battery and terminals, back in car tried again still nowt, gets back out takes positive term off battery waits 10 seconds reconnects, this freaks alarm out as i didnt do it properly, eventually de activates alarm manually inside car as the button on me key fob is missing, puts key in turns checks turned again she fired up first time!!
ps: i have noticed that when you turn her off battery light stays on for maybe 1 to 2 seconds but then goes off
over the last three days she's worked fine started first time everytime
many thanks to anyone who can shed some light on the situation
dave.
dave.
