Passive Steering?
- Bailes1992
Passive Steering?
Are the 406's supposed to have some form of passive steering?
I ask as all the dodgey bushes on my rear suspension have been sorted yet still when I stick it into a corner it feels like the back end is turning itself. You stick it into a corner then a split second later the back end tucks in tighter? Is this passive steering? Or is it more because my car's quite long?
Bailes.
Bailes.
- DaiRees
- Site Admin
Re: Passive Steering?
Yeah I think it has got passive rear steering. Can't say I really notice it but it can carry speed through corners pretty impressively for such a big old bus.
Mine's always chewed rear tyres, I notice the latest set are looking pretty bad too and I think they're not that old yet (haven't checked the milage yet). Might have to get the 4 wheel alignment checked but again I'm suffering the old problem that I just don't trust anyone to do it
. D'ya think I've got trust issues
just replace my rear bushes and rear track arms got a 4 wheel laser alignment done and the back end seems to give up easy on roundabouts always comes back ok have 3 good tyre need a new one just had a blow out tonite
- Bailes1992
Might pop up your way soon Dai and get you to have a drive of my car and see what you think
The 306 and the 406 have passive rear wheel steering which is kinda forced by loading the suspension sideways. Drivers will feel a 'shift' whilst in a bend as the rear sussy loads up.
Mine used to feel far too rear-endy at one point until I replaced the front tyres
Ihave always thought that strange feeling was with the car being so long
Dont blame you . My mother got all four tyres changed on her 307. A week later I noticed that one of the tyres was on backwards. I went mental and got it changed straight away. If its on backwards it retains water from the road instead if dispersing it. They changed it. They tracking was all off whack when we got it back and the wheels were out of balance. It took me a while to figure it out cos I wasnt driving it.DaiRees wrote:D'ya think I've got trust issues
Just got the tracking sorted in it last week. Ten minutes after the tracking was done perfectly (even got the printout), it started pulling to the left again.
Im just gonna bring it to a new place and tell them the whole story and how concerned I am about the cars safety condition. Then they might realise they will get grief if its not done properly.
- Bailes1992
Check thed rear wheels aint cambering like this...robb wrote:Ihave always thought that strange feeling was with the car being so long
If it is then the rear outer trail arm bushes need replacing if I remember correctly? Both mine had to be done.
Pulling on a cambered road or on the flat? 406s LOVE pulling towards cambers (especially the V6 with its vile variable PASeoin27 wrote:Ten minutes after the tracking was done perfectly (even got the printout), it started pulling to the left again.![]()
There's also quite a few other things that can cause pulling to the side, like not-quite-perfect subframe alignment, worn bushes, worn hub bearing, rubbing brake...
Its my ma's 307. No variable PAS thank god. I'll look into the above though.mjb wrote:There's also quite a few other things that can cause pulling to the side, like not-quite-perfect subframe alignment, worn bushes, worn hub bearing, rubbing brake...
Thanks for the photo Thankfully mine looks nothing like thatBailes1992 wrote:Check thed rear wheels aint cambering like this...robb wrote:Ihave always thought that strange feeling was with the car being so long
- Bailes1992
After having a load of rear bushes changed the back of my car's just started knocking like a whore house
Maybe I should sell it. Fed up of the car now.
