clutch died
Posted: Tue Mar 16, 2010 11:12 pm
by grendal13
im really stuck and could with some advice! my diesel 406 died yesterday the car was vibrating very badly went to the petrol station, engine running in gear with the clutch pressed down then for no reason it makes a clunk noise reves drops abit but seemed tobe fine,i took it out of gear released the clutch and a second later pedal dropped to the floor,i tried pulling it back but it sprung back down,turned the engine off and back on the pedal came up but it wont go down now no matter how hard i press.It goes in all gears no problem,but when the engine is started it sounds like the clutch is partially engaged as it make a slight grinding noise,any ideas? :cry:
Re: clutch died
Posted: Tue Mar 16, 2010 11:43 pm
by mjb
So the engine is permanently mostly disengaged from the gearbox, but there's still some hint of drive? I'd have to guess some of the clutch pressure plate fingers have snapped, freeing the release bearing, which usually pushes back against the pedal (via the release fork and hydraulics). If this happened, the slave cylinder piston will have been left in the 'pushing out' position because the fork's not pushing it back in. Pulling the pedal up, especially if there's a lot of friction on the piston, can cause extra fluid to enter the hydraulic system, causing it to jam
If it is this, repair could be costly - see my clutch change howto
Just a guess - I'm not a mechanic but I've spent a vast amount of time dealing with my 406s clutch.
Re: clutch died
Posted: Wed Mar 17, 2010 6:45 am
I'm not sure if this is a 1.9 (cable clutch) or a 2.1 (hydraulic) but, either way it sounds like it's new clutch time :( Actually, it reminds me of the time the release bearing on my Craptina (cable) ate through the fingers on the pressure plate...
Re: clutch died
Posted: Wed Mar 17, 2010 7:48 am
by puggy
Just had this problem , 2000 hdi pressed clutch pedal almighty bang pedal stayed
down , pulled it up would not go down again , thrust bearing had disintegrated .
Re: clutch died
Posted: Wed Mar 17, 2010 8:02 pm
by grendal13
is the thrust bearing difficult to replace on these?
Re: clutch died
Posted: Wed Mar 17, 2010 8:41 pm
by puggy
drive shafts out gear box out , may as well have clutch done at same :shock:
Re: clutch died
Posted: Wed Mar 17, 2010 9:25 pm
Is this a 2.1 or a 1.9?
Re: clutch died
Posted: Thu Mar 18, 2010 11:23 pm
by grendal13
its a 1.9
Re: clutch died
Posted: Fri Mar 19, 2010 5:45 am
Oops, I've just been reading my Haynes again and this one also has the pull-type clutch :( Have a squint viewtopic.php?f=5&t=10217&hilit=clutch+dmf#p90725. I think it's a case of make sure you have something you can use before offering the gearbox back on the engine...
Re: clutch died
Posted: Fri Mar 19, 2010 12:20 pm
by grendal13
thanks for all the replys, im gonna have a look over the weekend
Re: clutch died
Posted: Fri Mar 19, 2010 2:56 pm
by grendal13
ive just had a quick look and the hydraulic system is completly dry,how do i go about bleeding the system?
Re: clutch died
Posted: Mon Mar 22, 2010 9:42 am
by mjb
You can't - you'll need to acquire a replacement hydraulic system. About £200 from dealers iirc, or you can get one from a similar 406 in a scrappy. Changing is very easy - just push the cylinders inward and turn about 45 degrees anticlockwise to free them up
Re: clutch died
Posted: Mon Mar 22, 2010 9:49 am
But I thought the 1.9 was a cable :?
Re: clutch died
Posted: Mon Mar 22, 2010 10:31 am
by mjb
hmm me too...
Re: clutch died
Posted: Wed Mar 31, 2010 9:18 pm
by grendal13
ive decided to sell it for scrap anybody intrested? im in north wales
