Quick update,
ended up calling on the services of a local Peugeot Citroen mobile technician.... he uses a different diagnostic kit, and that
also pointed to the diesel pressure sensor. So a bosch part was bought and fitted by him, and so far so good (touch wood).
He was here for approx 3 hours in all cost me £170 ish inc the part which was £100 ish.
Hope it's sorted, will let you know!
Thanks for all your advice.
Steve
Throttle does not respond at all (only sometimes)
Re: Throttle does not respond at all (only sometimes)
My other Peugeot was a D4B
Well, another month has passed, and I am pleased to report, this problem now seems to be cured.
Many thanks for all the help and advice.
So to summarize, it was the DIESEL PRESSURE SENSOR.
It usually is
pleased you got it sorted.
Hi I have a 406HDI with similar issue, no fix as yet but am hopefully someone will have solved it. I started having lack of power issues and replaced some of the vacuum hoses that controlled the turbo. Seemed to fix, then noticed the idle RPM started to increase over a week or so idle was about 1400. Then total loss of throttle response, checked the cable it was fine and was turning the wheel on the TPS. replaced the TPS (not easy to find in Australia) it did not fix the gault. The car has been sitting for sometime I started it up and left it to charge battery and keep run AC to keep seals ECT wet, the engine was idling at 1400 after about 10 minutes it started revving about 3000 and would not turn off! I was about to put it into gear to stall it and as I put my foot on the brake it shut down with a big STOP on the instrument display.
Started it up again went to 3100 rpm and as before wouldn't turn off. I am now lost for what next, maybe an ECU to
Do you have any water under the drivers side carpet? It must rain sometimes in Australia.
I agree with Peter and suggest to look for water ingress in the driver's footwell and boot cubby hole by the CD changer
I wouldn't choose to swap the ECU as it's paired to the BSI which is more bother than it's worth ( unless it's a last resort )
