A/C compressor
- puggy
- Resident Pervert
Re: A/C compressor
its called a DHYD Pressure switch and screws onto an outlet on the condensor .
- mjb
- Site Admin
Re: A/C compressor
I mean I can't see any way for it to screw in from your pictures - it looked like that black bit might have been force-fit or something
Re: A/C compressor
Looks like he's put the plastic plug (from the new packaging) in the female thread of this old part.
- puggy
- Resident Pervert
Re: A/C compressor
Is there a prize?
- puggy
- Resident Pervert
Re: A/C compressor
Yes you have won the pressure switch !!
please forward me your address details also your bank account details and
any utility bills you may have lying about
Re: A/C compressor
Does it leak? I've heard these can be faulty.puggy wrote:Yes you have won the pressure switch !!![]()
If I post you my passport and driving license, 3x utilities, my credit and debit cards (with PIN No's) will that be ok? once you've taken your payment if you could just pop them back in the post for me when you get a moment
- puggy
- Resident Pervert
- Site Admin & Mad Biker!
Re: A/C compressor
Send me your address, credit cards and passport and I'll post you a moppuggy wrote:![]()
i.m on the floor here pissin myself
- puggy
- Resident Pervert
Re: A/C compressor
stop it ! stop it !
will it be a genuine peugeot mop
Re: A/C compressor
Oh yes, I'll stick a lion's head to the handle!puggy wrote:stop it ! stop it !![]()
It'll be "the mop of your life! "
Re: A/C compressor
Quick, someone nick his wallet while he's incapable of resisting.puggy wrote:stop it ! stop it !
Probably just needs a seal. 10p from your nearest plumber's merchants.Welton wrote:Does it leak?
- Location: either in my Audi SQ5+, X- trail Aventura or Mini Cooper Cab
Re: A/C compressor
A/C stopped working today
So car was fully steamed up driving to work. Had to open the windows to clear it.
I thought more money
Yes its the same as puggy my pressure switch has just started leaking but my ac is working intermitent.
My a/c guy said its the third peugeot he has done in around 15 years
The uv dye has run onto the connetors and its causing it to work one minute and then not the next.
He has cleaned up the connector and hopefully it will last till next wek when its replaced
Re: A/C compressor
Bugger! that means another regass
Re: A/C compressor
It has a very slow leak as it is still working. It has a shyder valve i think he said so it wont need a re gas thank god
Just a top up which he will do for free. Pressure switch including fitting £45 so not to bad i suppose
