Please Help (Sorry)
Re: Please Help (Sorry)
Hey Guys got a top mechanic in and he said no way its the HG (!Thank God!) and he said its doggy fuel so i need to replace the Fuel Line,Filter and the exhaust gasket and drain the fuel tank and refill with Redex so how much is it gonna cost me guys and labour ? But i wanna thank everyone for giving there advice and help.
Glad it wasn't the head gasket but the bad fuel is a bit of a bummer. Can't help you with costs (how long is a piece of string??) but disposing of the dodgy petrol will cost a bit too I'm afraid.
- Site Admin & Mad Biker!
It shouldn't cost the earth, I'm not sure what others would say but surely the fuel line wouldn't need replacing?
I'm not sure what the contamination was but it would probably be ok to flush it out with some clean petrol.
Thanks a lot guys yeah i need to drain the petrol out and change the exhaust manifold gasket and then fingers cross. So ill wait till Monday and ill let you guys updated thanks guys.
Right i got good news and bad news? I got the car running fine by having new set of spark plugs but when i drove off it was juppering really badly and i got told my spark leads are f**** so am gonna change that but guys i noticed my compression is 130 which should be 180 and the mechanic said my engine might be getting tired
But i been herad my 406 Turbo is still a young engine at 150k well i hope it is lol please guys any surgestions and what can i do to make the compression higher.
Thank You
Thank You
Oh blimey, your car's definitely got it in for you!
Was it you or the mechanic? Any of you guys know the right cranking pressure for this engine?
If the pressure has dropped then it's either blowing past the rings or past the valves. What you can do is stick some engine oil down the plug holes and then test the pressure again, if it shoots right up then I'm aftaid your rings/bores are on their way. If not then it's probably the valves, you'll have to have the head off and regrind them.
Does it smoke at all and, if so, when? (You might have to have a friend follow you...)
Or, if it runs ok with the new leads, you might be better off ignoring it...
- mjb
- Site Admin
Bah I was going to suggest that! Saw it on telly the other day... Can't remember what program, probably either 'Wheeler Dealers' or 'A Something Is Born'... ;)steve_earwig wrote:What you can do is stick some engine oil down the plug holes and then test the pressure again, if it shoots right up then I'm aftaid your rings/bores are on their way.
Thanks guys but yeah its starting fine now with new spark plugs but theres no smoke at all and its just jubbering when i accelerate? i hope it isn't anything bad but i ordered some Performance Leads to hopefully solve it?
They didn't show them here...mjb wrote:Bah I was going to suggest that! Saw it on telly the other day... Can't remember what program, probably either 'Wheeler Dealers' or 'A Something Is Born'... ;)
Let's see what new leads do, although I have a feeling turbos are subject to coil failures. I remember a forum but I can't find it (prokleti hakeri).
Very Strange?
Hi guys just started her up and she was fantastic went for a drive and she started out like normal and no over heating nothing fantastic until i get past 4k and she started to jubber? I haven't changed my spark leads and i haven't put and Redex just yet just wanted to test her i hope doing the leads and some good fuel she will be ok? Or dono what you guys think?
I'm hopeful about those new leads, it does indeed sound like an ignition fault. Although we could do with some input from those with experience of turbos. Maybe I need to shout:
TURBO MISFIRE HELP!
TURBO MISFIRE HELP!
- mjb
- Site Admin
what do you mean by "jubber"?
Isn't he that fat guy out of Star Wars?
I've been reading that as "judder".
- mjb
- Site Admin
That's Pizza the Hut ain't it?steve_earwig wrote:Isn't he that fat guy out of Star Wars?
