6 speed Citroen on eBay
Re: 6 speed Citroen on eBay
I bid up to £325 but was out bid - I guess it wasn't meant to be.
£387 somebody was keen.
I hope they find welly's £30
Doggy wrote:I hope they find welly's £30
I hope the buyer gets a decent car, then de-faps, de-EGRs and throws a remap on it and thoroughly enjoys it.... :cheesy:
The £30 was Monopoly money.. :wink:
MyPug
Post by MyPug »
I have noticed that some of you have 6 speed manual gearbox in your 406.
What model did you get it from, was it strait transplant, lot of work?
2003 HDi, 90HP (DW10TD), saloon D9, 5 speed manual (ML5C), silver met (EZR).
Hi, only the 6 speed from a C5 with the same 2.2Hdi engine will fit - its a 20MB04 I think, or 20MB02...
There are a couple of little things to change over but its well documented on here.
jonsowman
Post by jonsowman »
20MB04 is the one :) Haven't seen one on eBay (or anywhere else) in quite a while though.
MyPug
Post by MyPug »
My reason for having a 6th gear is to lower rpm at high speed.
At 2000 RPM in 5th gear, speed is about 55-56 MPH.
Gearbox; BE4 L,
Ratio; CP 19 X 77
In 6th gear, what is the RPM, speed being the same?
MyPug
Post by MyPug »
Thanks to everyone for the replies, most kind of you all.
Yes, my engine is 90HP RHY (DW10TD).
I thought that my 90HP DW10TD and 110 HP DW10ATED has the same block? Not sure of the 2.2 litre block.
Will do some more search to figure out the difference between engine blocks, mounting etc.
Maybe drive shafts are different from what I have, even chassis mount. Now that would complicate it further.
Replacing engine is not what I'd like to do as it is in very good condition.
90. 110 and 2.2 engines all have the same block, (2.2 is longer stroke/same bore).
All have different flywheels and clutch housings - 90's typically have a BE3 or BE4 series gearbox.
110's and 2.2's both have an ML series gearbox, but they have different input flanges to suit the specific engine.
You may be able to fit the 6-speed BE series gearbox from a 306 GTi-6, but I suspect the final drive ratio would not suit a diesel.
I don't believe it would be straightforward to fit an ML6C to a 90 and I think neither 2.0 engine would have enough torque to pull 35mph/1000 RPM in 6th.
Doggy wrote: I think neither 2.0 engine would have enough torque to pull 35mph/1000 RPM in 6th.
Fit 13" wheels? :P
MyPug
Post by MyPug »
Would it pull 55 MPH at 1500 RPM?
Thanks.
MyPug
Post by MyPug »
So this could mean that I will use more fuel that I currently do, and stress the engine whiles driving.
I never thought of that.
What I have is adequate so I will keep it as it is.
Thank you - much appreciated.
It is really good to have a forum where such knowledge flourish.
