So a while ago i got an anti pollution warning - my local garage reset it (but didn't have the reader) and it went away.
It came back with a vengeance a week or so ago and its taken the fuel gauge with it. The fuel gauge now commonly reads incorrectly, sometimes telling me i have 3/4 fuel when i have almost none. At other times it reads correctly. So im having to keep note of my millage and average fuel consumption :/
I managed to get an appointment at a garage with a reader and guess what, that morning the fault disappeared and the garage found no logs in the system. It came back 2 days later and has been there every since and the fuel gauge is still reading wrong.
At no point has the car been in limp-home mode
This all seemed to start when i fitted the sub woofer and while connecting the power to the battery a spark jumped to these pipes >
http://i9.photobucket.com/albums/a62/Zi ... 142933.jpg
http://i9.photobucket.com/albums/a62/Zi ... 142925.jpg
Ive heard they are fuel injection pipes and power steering pipes - so someone is wrong, but if they are fuel related its almost to big a coincidence.
I know i havn't explained this well at all [im in a rush] but please feel free to ask me more questions - can anyone work out what the hell is going on with my pug!
Got the dreaded Ani-polution fault
- mjb
Re: Got the dreaded Ani-polution fault
The black metal pipes coming out of the silver metal block? They're brake pipes coming out of the ABS thingy.Zippokovich wrote:This all seemed to start when i fitted the sub woofer and while connecting the power to the battery a spark jumped to these pipes >
Having the battery live arcing to ground through stuff that's connected to the ECU is very, VERY bad. The only thing I can suggest would be to disconnect the battery for 20 mins and hope the problem goes away
Done that beforemjb wrote:The black metal pipes coming out of the silver metal block? They're brake pipes coming out of the ABS thingy.Zippokovich wrote:This all seemed to start when i fitted the sub woofer and while connecting the power to the battery a spark jumped to these pipes >
Im convinced its a fuel/gauge problem of some sort
I had an erratic fuel guage on my 2.1TD which I cured by removing the main instrument cluster and reseating the 2 multiplug connectors there. The gauge used to go mental during hot weather and I finally sussed it was a poor connection on the plug behind the dash...
Worth a check if the problem has coincided with the recent warm weather we have had recently
Ok I will check that, thanks.
But I still have suspicions its to do with the engine mamagment prob. Does the computer control the guage or is it a direct sensor from the float?
And its not really 'eratic' it stays stable and dosnt move - it just moves drasically in the wrong direction over night somtimes :/
