So yeh i found out my air con is broken and is going to cost £300 to fix.
Dose that sound about right for a new compressor, pipe and labor at a private garage?
And would you guys spend that? i don't think im going to
Air con broken
Re: Air con broken
Sorry, i posted this in the completely wrong place, can an admin please move it into the right section.
- mjb
Re: Air con broken
where to? engine&mech is where I'd put it...Zippokovich wrote:Sorry, i posted this in the completely wrong place, can an admin please move it into the right section.
Re: Air con broken
Sounds cheap if it includes a Compressor are you sure it's not the more common 'condenser' ?
I thought a new compressor alone is £500.00+
Re: Air con broken
Oh well, i would say electrical - but whatever!mjb wrote:where to? engine&mech is where I'd put it...Zippokovich wrote:Sorry, i posted this in the completely wrong place, can an admin please move it into the right section.
Dam your right, it was the condenserWelly wrote:Sounds cheap if it includes a Compressor are you sure it's not the more common 'condenser' ?
- puggy
- Resident Pervert
Re: Air con broken
Thats about the going rate to have a condensor replaced , and re-gassed .
Re: Air con broken
Dam, oh well its no where near worth it then.puggy wrote:Thats about the going rate to have a condensor replaced , and re-gassed .
Thanks!
Re: Air con broken
That's a shame - this summer's supposed to be a long period of warm consistent weather (apparently) so depending on what you use it for/where your going mostly then I'd think long and hard about it.Zippokovich wrote:Dam, oh well its no where near worth it then.
The 406's a/c is brilliant! if you're handy you might be able to fit the condenser or get a friend to help etc. and then get a mobile a/c guy to gas it? you should be able to get the whole lot done for £200.00 I'd say.
Re: Air con broken
It needs a pipe too, apparently thats the killer with the part costing £100 its self.Welly wrote:That's a shame - this summer's supposed to be a long period of warm consistent weather (apparently) so depending on what you use it for/where your going mostly then I'd think long and hard about it.Zippokovich wrote:Dam, oh well its no where near worth it then.
But nah its a 51 plate LX 1.8 D9 so its only worth 1500 is even that. So its not worth spending £300 on, especially with its other minor niggles.
Im considering getting a new 406 and trading it in as in this topic > viewtopic.php?f=7&t=7530
