Can anyone tell me how to remove / loosen the ECU Housing from chasis. I need to get to the lower Power steering hose as its leaking. I can see and loosen one nut and there is a clamp on a hose which i can detach but the housing wont budge and I cant see any other places where its held on.
Rich
ps D9 2.0hdi 90
ECU Housing
- mjb
Re: ECU Housing
There's a screw/nut at the bottom of the ECU box on the inside, and another one on the outside corner of the box near the light cluster if memory serves
Re: ECU Housing
As far as I remember there's two on the outside (one down the side of the chassis rail, bitch to get to) and one inside.
Re: ECU Housing
cheers guys. had look and can see the one inside so ill whip that out and see what happens.
