My discs look close to being worn out, can anyone recomend some upgraded discs, i'm not talking 6 pots with dustbin lid sized discs, just an increase in stopping power.
I had some Brembo high carbon discs, greenstuff pads and stainless steel hoses on my old clio 172 and they were incredibly good, does anyone know of any good discs/pads for the 406?
its a 2.0 TD with ABS by the way
Matt.
Brake upgrade
Brake upgrade
2000 2.0 HDI Estate GTX 90 bhp
- DaiRees
Re: Brake upgrade
I do believe some of the coupes and V6s had brembos with bigger discs, but you'd need to change to wheels too for clearance.
Someone else will know more I'm sure
- mjb
Re: Brake upgrade
Just the V6 coupe - they weren't fitted to the saloon/estate. You need the coupe's 16" wheels too as the increased size of the calipers means the 15"ers won't fit. They also have a bad problem with squealing.
- linukas
Re: Brake upgrade
i have changed my Lucas brakes to brembos, for conversion you need: brembo calipers, discs from 3.0 v6 and bigger alloys. Cause on v6 they are 16 inch with ET15
Re: Brake upgrade
that sounds like more modification than i really want do, dont any suppliers just do better quality discs and pads that will fit straight on?
no probs if not i can stick with standard, just thought i'd look into it seeing as they'll need to be replaced soon.
- DaiRees
Re: Brake upgrade
Oh sorry fella, that was me not reading your original post properly....
A quick google shows that EBC do drilled and grooved discs and Greenstuff pads. I'm sure there'll be others...
- HimBigChief
Re: Brake upgrade
Check out this site here, lots of different upgrade options.
http://www.needforspeed.co.uk/pages/sbv ... le=PG40601
- 1.6 8v
Re: Brake upgrade
I can recomend the Black Diamond Discs and Pads. I've got 2 D9 V6s, one with the OE discs and pads and one with groove/drilled discs and the predator pads, the BD parts take a bit of warming up but the difference is very noticable and I'll be upgrading the OE parts soon on the 2nd one!
