Radiator Fan Switch??
- 1.8 8v
Any peeps know where the radiator fan switch is on a 2.0 Turbo exec??
Re: Radiator Fan Switch??
In case no-one with a better idea answers, they're usually on the thermostat housing.
- Site Admin & Mad Biker!
There's a lot of good info in this thread
- 1.8 8v
cheers, but no help there
im looking for a 3 pin switch but am stumped if i know where it is , i've pulled out so many frikkin switchs (all seem to be 2 pin)?!?!
- mjb
There's no switch. It's controlled by a separate bitron ECU. You can test if the fans are working by pulling the plug from the coolant temperature sensor at the back of the thermostat housing. That should cause the fans to run at full speed when the ignition's on
