Turbo dismount
Turbo dismount
Is there easy way to dismount turbo of HDI 2.2? Two mechanics told me that it is too hard on that model. Maybe there is a trick which is not obvious.
Re: Turbo dismount
Maybe there is some "how to" video at Youtube or Autodoc?
Re: Turbo dismount
Sorry for the lack of response.
Personally I never had to touch either of mine in 7 years and 200k miles
I also don't remember anyone else having to.
It is likely you will find more information on the coupe website: http://406coupeclub.org/PHPBB3/
Re: Turbo dismount
Seems to be a big job:
http://406coupeclub.org/PHPBB3/viewtopi ... 93&p467393 : "it was a 1,5 day job and took us about 8-9 hours"
https://www.peugeotcentral.co.uk/ftopic-16927.html : "it took me 4days"
Mine is a HDI 2.0, currently at 680.000 kms (425000 miles) and never had to replace the turbo. I don't have experience with a HDI 2.2 .
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 690.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
![Cheesy Grin :cheesy:](./images/smilies/icon_cheesygrin.gif)
Previously owned:
Re: Turbo dismount
But then again: http://406coupeclub.org/PHPBB3/viewtopi ... 16#p439616
"Time to replace was around 4.5 hours, OSF driveshaft was removed to gain access to remove and refit the turbo, got told it wasn't too bad to do!"
Current "fleet":
Previously owned:
Previously owned:
Re: Turbo dismount
Is this 4.5-8-9 hours for dismount + remount or only for dismounting?
Re: Turbo dismount
For dismount + remount (is what I read from the forum posts)
Current "fleet":
Previously owned:
Previously owned:
Re: Turbo dismount
It seems the geometry of my turbocharger is not moving and for that reason I have to dismount it. But I am afraid that the problem can be different and such complex operation can be waste of time (money).
Re: Turbo dismount
Have you eliminated the possibility of an external problem, (vacuum leak etc.) preventing the turbo from adjusting?
Re: Turbo dismount
Agreed - generally the turbos are very durable.
If you follow the vacuum hose from the turbo to the solenoid, you can pop it off the solenoid and suck on the pipe.
Use your tongue over the end to hold the vacuum, and listen out when you take your tongue off - you should hear a 'ping' noise
If no ping then maybe the turbo is gummed up from the EGR valve putting soot back into it. There is a trick of filling the turbo with Mr Muscle or similar ( via the EGR ) to dissolve the sticky gunk in the turbo.
There is more information on the Coupe forum about this.
Good luck.
Good luck.
Re: Turbo dismount
I did mine about 4 years ago. Took me about 3hrs from memory to get it out. Real fiddly faff of a job from memory. I did it as my variable vane system was jammed up with carbon. Cleaned it up and put it back... an even bigger fiddly faff from memory....
I definitely undid the lower mount so I could swing the lower part of the motor forward and used a block and tackle system to remove the upper driver's side mount and support the engine, which allowed me to move the top part of the engine forward to give me more room to get to some of the turbo/manifold bolts from the top. Exactly how I achieved it is very foggy in my senile brain, but took me less than a day to remove, clean and replace.
Serial 406hdi licker ![Cheesy Grin :cheesy:](./images/smilies/icon_cheesygrin.gif)
Re: Turbo dismount
From older diagnostic I know that electrovalve 1628.HC probably is in bad condition. Don't know what exactly is its role and whether there is only one 1628.HC or they are two. At that time the problem was check engine lamp above 3500rpm. (I have not replaced 1628.HC yet.)
Re: Turbo dismount
The electrovalves are interchangeable, so you can swap the pipes/connector with the one next to it and see if it the problem persists.
If it does then it may be a split vacuum pipe somewhere in the system...
Re: Turbo dismount
I think there are at least 2 types of valves - 1628.HC and 1628.CH. Don't know what is the difference but the price was different.
Re: Turbo dismount
Is there scheme from ServiceBox or other source with OEM codes for the 3 valves?
