Peugeot 406 judder at around 1400-1600 RPM
MyPug
Re: Peugeot 406 judder at around 1400-1600 RPM
Post by MyPug »
Had the freewheel alternator pulley replaced today and that made a really big difference on the judder. It is still there but I don't notice it as much as before.
Perhaps there are other pulleys with vibration dampers that are failing.
2003 HDi, 90HP (DW10TD), saloon D9, 5 speed manual (ML5C), silver met (EZR).
MyPug
Post by MyPug »
Another ting I noticed is that when I started and stopped the Diesel engine, it shocked violently. But after I replaced the alternator pulley it is much smoother when starting and stopping.
MyPug
Post by MyPug »
I ordered a Pressure Control Valve (PCV) today from Merlin Diesel and it is a genuine VDO part Made in Germany. So it should be of good quality. Part number A2C59506225.
When I have replaced it I will post the result. Fingers crossed.
MyPug
Post by MyPug »
The Pressure Control Valve (PCV) has been replaced and it didn't help.
The judder is still present at 1500 RPM. And now, after replacing the PCV it has started happening at 1800 RPM as well. So it has become worse. It feels like it is all over the place. Particularly when the engine load is light, for example driving steadily on a flat road.
Not sure where to go next. Any input to help solve this mystery is much appreciated.
frog
Post by frog »
Maybe it is a bad engine mount?
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
