Boost gauge install hdi 90
Gilly
Post by Gilly »
Hi guys,
Can someone clarify where to plumb a boost line into on the hdi90.
As this has no intercooler do I tap into the intake manifold or is there an easier option?
Would like to know what my turbo is doing...
Thanks in advance!
2001 HDI 90bhp - current daily
frog
Re: Boost gauge install hdi 90
Post by frog »
This is the diagram showing the turbo pipes.
If you have an air doser, that seems to be the best place to drill a hole.
Otherwise in the 90 degree hose no. 4.
Think it is best to detach the hose when drilling a hole in it, to prevent the debris from entering the inlet.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Gilly
Post by Gilly »
Thank you very much for your reply! This helps a lot.
I’m considering adding an intercooler so this also helps the pipe layout for me.
frog
Post by frog »
Gilly wrote: Wed Sep 18, 2019 8:14 am I’m considering adding an intercooler so this also helps the pipe layout for me.
Here is a diagram of the extra plumbing you'd need:
Current "fleet":
Previously owned:
The fan cowling and engine cover is also different - just something to bear in mind.. :cheesy:
