throttle position sensor failure
Hi all I have a stuffed tps and finding it very difficult to find one for my 2.2 hdi but I have found one for a Peugeot 607 2.2 hdi 2004 automatic can anyone please tell me if this would fit mine its a 406 2.2 hdi 2002 many thanks again Paul
Re: throttle position sensor failure
Hi, I think all the TPS for the Hdi's are the same - its only a spring inside a plastic case.
i removed one from a 110 Hdi which looks the same but on a different bracket, i.e. the 2.2 has a 10mm bolt and the bracket slides off to the left, but the 110Hdi had extra fixings.
I may have one on my donor 2.2Hdi vehicle still, I'll check - but I'll see if the 110Hdi will fit on my 2.2Hdi and post up the results.
Hi that would be great Paul
