Starting issue 2.1
Re: Starting issue 2.1
Just had car hooked up to a computer it's sayin crank sensor or a injector and the rev idle is low some sensor on the idle speed cleared the faults and plug in again tommrrow see what comes bk
Pin sensor inside of injector has gone so need another
Right it's had a another injector witch took away the sluggish ness out change crank sensor but still won't start it's alot easier to start and keep running but it won't do it with out me revving could the idle sensor cause this ?
sounds a bit like mine , think i`ll get thr filter lid seal changed cos was thinking that couls be a point of entry
this issue has developed over 5000 miles of motoring for mine
was ok when got it
November 2010
wouldnt start (no glow light showing ) pulled all fuses in box behind battery one -by -one and replaced , eureka ,glow light and start no problem
only got replacement matrix to finish off -- was still leaking after fitting , TEMP bypass (3" 22 mm pipe with hoseclips )while doing the matrix job with silicone sealant while tightening up screw , acid test when refitting engine bay hoses on matrix then refit center console and glove box fingers crossed
was ok when got it
November 2010
Replacement !
we have a diagnostic port on our 2.1 td `s ???
where is it please ??
Replacement !
I believe it's next to the driver's knee fusebox. Remove that plastic trim panel, it's white and sort of rectangular...
It's not OBD compliant by the way, I believe PP2000/Lexia are the only things that can talk to it.
Ye plug is on the right hand side of plug and ye not all machines will read ur car lucky for me the garage I no had the right tool that is
My next job the fuel filter housing going to get the comp put
Bk on the car see if any other faults have popped up I wanna do
Loads to the car but can't coz this starting problem is stopping me I
Got d9 leather door cards to fit lowering springs alloys window tints and possible paint job de badge front ent smooth bumper strips
Pump was out on the timing adjusted pump and it starts bit lumpy but clears so gonna get cam belt changed next week and hopefully it will run like new
idid say check timing
glad to see you got it sorted tho,
Indeed u did Just got to go
Get the kit and change it then in with the mods I'll get some pics soon
