Heater
- 2.0 Turbo
Heater
Heater fan not going and seems to be leak on matrix
Replacement !
- 2.2 16v
Re: Heater
How do you know its a leak?
- 2.0 Turbo
Re: Heater
cos theres water in the footwell with a slight rusty tinge to it and water level going down but not quick
Replacement !
Re: Heater
Hi archangel, my heater blower stopped working a while ago. I checked all sorts and asked questions. It eventually tracked down to the ignition barrel. When I start the car and the fan does not run then I just hold the ignition key and put a small amount of upward presure on it and the fan starts ok. It has something to do with the cables on the back of the switch I think being loose or the age thing where they come loose. I have not bothered to remove anyting on mine because I am lazy. Sorry I dont know how to get the matrix out.
2000 ltr LX Deisel HDI. Gold colour. Running with a Citreon Piccaso engine (52model)
- lozz
Re: Heater
Matrix is a pain to remove,
the dashboard support bar gets in the way,
- 2.0 Turbo
Re: Heater
anyone know what size of pipe feeds from engine to heater matrix , was thinking about bypassing matrix till i can get it exchanged to keep the leaking down
Replacement !
- lozz
Re: Heater
iused a peice of one of them metal Broom handles,
once, its the right thickness
(U-shaped loop is best imo, copper pipe and pipe bender needed for that tho)
But make sure you get all the airlocks out of it , if you by pass-it,
ive seen headgaskets blow after people have by passed Matrix, be carefull mate,
- 2.0 Turbo
Re: Heater
cheers lozz
better than having it blow allover the passenger side though, did that with the 306 I had , not fun !
Replacement !
