![Smile :)](./images/smilies/icon_smile.gif)
thx
maybe I complicate too much, but after full time job, I am relaxing with cars lately
there should be enough room i guess but there are several things that make me problems:
1. about cruising in 6th gear - we have tested this and it should be fine i hope (several posts before)
2. am not really sure about speed sensor - what will happen...if it is not working correct even air bag error appears
- had that experience yesterday when I changed map of EGR - tried to turn it off by modifying the EGR map in hexdump, but I was stupid because car went into the limp mode (a lot of things depends on egr map) and as I discovered something was in short circuit and also speed sensor wasn't working normally, i got even airbag error because of fault on speed sensor,
today i know that there is switch 000/001 in another map that turns of the EGR
and now i know how to disable it
3. there is problem for axis - my good friend had horrible experience, he changed the gearbox - all numbers where the same but from another car, there was around 2mm difference in some "angle" of axis and that could not be noticed by eye, everything fit great...after 1000km, the oil started to leek from it and after that it broke.
I will check repair manuals for
ML5C 20LM02 vs. ML6C /L 20MB01
everything has to be 100% same in connecting gearbox to chassis, and fitting the axis (angle)...am I right?
maybe there i can see if it will fit.
The problem is that for every gearbox i try and compare i have to tell the guy who is selling it that if it wont fit I will bring it back (it costs about 350€), and nobody is happy about this kind of business
I hope the repair manual will tell me more, that I will be certain which type of gearbox will be the right one, because it is really stressful to call around buy it compare and than bring it back
![Embarassed :oops:](./images/smilies/icon_redface.gif)
i do not like that...
Can anyone send me manuals for those two gearboxes maybe,
it would help a lot ![Smile :)](./images/smilies/icon_smile.gif)
