2.1td cambelt change, now starting problems
well, I did the cambelt and aux over the weekend, the only problem now is difficulty starting, its almost as if the preheat doesnt work, the only electrics i disturbed was to disconnect the battery and take of the starter motor for access to the crank locking hole.
when it runs it runs cleanly with no smoke, pull's like a train which makes me think its not to do with mispositioned cambelt, it was all working fine until the belt change.
if the belt was out would it cause this problem, as i say it ticks over and runs fine, no missing etc, any ideas?
'97 2.1TD Estate
Re: 2.1td cambelt change, now starting problems
Check the juice to the glow plugs, might just be an earth lead you knocked when locking the flywheel pin.
2.1td exec estate.
thats what im hoping mate, 'cause I aint taking that belt off again !!!!StevieboyTD wrote:Check the juice to the glow plugs, might just be an earth lead you knocked when locking the flywheel pin.
'97 2.1TD Estate
just checked the glowplugs and their getting getting power so i suppose the belt must be out slightly, im gonna have to live with the slow starting, I dont want to see that cambelt again!
'97 2.1TD Estate
ricasso wrote:... 'cause I aint taking that belt off again !!!!
Filling me with confidence here, i'm doing mine soon!ricasso wrote:... I dont want to see that cambelt again!
2.1td exec estate.
i think the answer is , get the missus to do it! it takes small girly hands to get down that side of the engine......
'97 2.1TD Estate
no uneven idle, no engine light?
Hmmmm, straight 6 goodness!
nope, idle's sure and steady and no engine light, no smoke or even haze, in fact ive just come back from a 20 mile drive and i have to say i was impressed with the way the old girl wanted to get down the road!poddack wrote:no uneven idle, no engine light?
just had a thought, is there something else that could be fine tuned given that the new belt doesnt have the "stretch" that the old belt might have had, could something have been adjusted to compensate for the old belt?
'97 2.1TD Estate
Did you disturb any fuel pipes?
try the priming bulb in a morning, if it's soft you're probably leaking air into the fuel system.
2003 2.2 HDI SE
2003 2.2 HDI SE
I didnt disconnect any fuel lines,just moved them out of the way, but i'll try the bulb tomorrow morning.gumby6371 wrote:Did you disturb any fuel pipes?
'97 2.1TD Estate
