My running 406 is a 96 XUDT and the breaker is a later HDI so I assume they are different. If you want the headlight I can rip it out and check.GingerMagic wrote: ↑Tue Aug 07, 2018 10:58 amCool, thanks.
The display is easy to remove, just pop out the little cover either side of the display and undo the 4 torx screws.
Pull it out and unplug the black connector - it's one that you need to lift a clamp first before unplugging it.
The headlights are only different on phase 1 and phase 2 models ( D8 phase 1 has the indicators on the black rubbing strips - D9 phase 2 has the indicators nearer the top of the wing )
It's a pain to remove, but if you have a flexible socket set then you should be okay. One 10mm bolt in top, one down the side behind the grill, last one is tucked away on the inner wing - this is the tricky one.
406 HDI estate parts available
Re: 406 HDI estate parts available
- GingerMagic
The headlight is Indeed different between your runner and your spare - only the doors, tailgate, bumper and rear lights are compatible - everything from the windscreen forward is not interchangeable.
I'll let you know about the headlight shortly.
Thanks.
Thanks.
1999 T4 family wagon
2005 Vauxhall Meriva
Probably going to the scrappy next week.....
- GingerMagic
Hi, I've decided to sell my recently purchased estate car, as I've bought a V6 Coupe instead, which was a bargain...
My friend would still like the MFD, so if you wouldn't mind giving me a price Inc postage and I'll pass the information on.
Many thanks,
Kelv
Many thanks,
Kelv
Sorry for the delay - scrappy made me an offer I couldn't refuse so car has gone to great car park in the sky. Never like scrapping cars but needed the parking space and got very little interest in parts for sale.
