Fault code unknowns
bigknickers
Fault code unknowns
Post by bigknickers »
Hi gang, my friend read my 53 plate hdi estate fault codes and told me I had these;
p0113
p0400
p0341
p1353......................eeerrrrr, what are they?
Re: Fault code unknowns
Hi, have a look in the Knowledge Base Articles on the forums home page - you will find a topic called ' the list of doom '
All the codes are there, I would have a look but I'm in the middle of dinner...
Ignore the pre/post heating relay fault - they all seem to have it and it doesn't really affect the Hdi.
1999 T4 family wagon
2005 Vauxhall Meriva
bigknickers
Good man Ging..........I'll have a look thanks n bon apetite!
bigknickers
Two on that list are camshaft sensor and air intake temp sensor...................are these easy to change?
Yes, the cam sensor is slightly hidden inderneath the wires that are running across the top/left of the engine itself - although if it was faulty then the car wouldn't start...
The Air intake sensor is the MAF, its showing a fault as its unplugged :cheesy:
