Fault code unknowns
bigknickers
Fault code unknowns
Post by bigknickers » Fri Apr 20, 2018 7:00 pm
Hi gang, my friend read my 53 plate hdi estate fault codes and told me I had these;
p0113
p0400
p0341
p1353......................eeerrrrr, what are they?
Re: Fault code unknowns
Post by GingerMagic » Fri Apr 20, 2018 7:08 pm
Hi, have a look in the Knowledge Base Articles on the forums home page - you will find a topic called ' the list of doom '
All the codes are there, I would have a look but I'm in the middle of dinner...
Ignore the pre/post heating relay fault - they all seem to have it and it doesn't really affect the Hdi.
1999 T4 family wagon
2005 Vauxhall Meriva
bigknickers
Post by bigknickers » Fri Apr 20, 2018 7:44 pm
Good man Ging..........I'll have a look thanks n bon apetite!
bigknickers
Post by bigknickers » Sat Apr 21, 2018 7:56 am
Two on that list are camshaft sensor and air intake temp sensor...................are these easy to change?
Post by GingerMagic » Sat Apr 21, 2018 8:51 am
Yes, the cam sensor is slightly hidden inderneath the wires that are running across the top/left of the engine itself - although if it was faulty then the car wouldn't start...
The Air intake sensor is the MAF, its showing a fault as its unplugged :cheesy:
