Buzzing noise
caprixpack
Buzzing noise
Post by caprixpack » Wed Apr 04, 2018 10:12 pm
There's a rather loud buzzing noise coming from behind the dash on the drivers size of the GTX. It doesn't always happen, at first I thought it might have been the radiator fan but it's not and it can't be heard outside of the car only from inside. Any ideas?
Re: Buzzing noise
Post by GingerMagic » Wed Apr 04, 2018 10:20 pm
Is it definitely the drivers side?
There is a recirculation motor that sits behind the dash but nearer the glovebox side - this has been known to make a racket when its opening the fresh air flap, some of them have ruined cogs where the flap has been jammed for years and its stripped the teeth off..!
When I bought my 2nd 406 ( ex-taxi, eBay purchase, many issues :frown: ) the fresh air flap had to be broken off as it was stuck solid, you can only imagine the smell in that car when I first got it....
1999 T4 family wagon
2005 Vauxhall Meriva
Re: Buzzing noise
Post by Doggy » Thu Apr 05, 2018 12:40 pm
I was thinking the same thing, (recirculating flap gubbins).
Another possibility you get with 110's of that age is a buzzing noise from the bulkhead area that typically lasts for maybe 15-20 seconds after stopping the engine, (I think it comes from one the vacuum solenoids that control the egr/wastegate/air doser)
caprixpack
Re: Buzzing noise
Post by caprixpack » Thu Apr 05, 2018 2:32 pm
The noise stops as soon as you turn off the engine. It seems to come and go sometimes only on for a few minutes other times it lasts for 10 to 15 minutes. Strangely it can't be heard in the engine bay and after a bit more listening it seems to be coming more from the middle of the dash.
PeterN
Re: Buzzing noise
Post by PeterN » Fri Apr 06, 2018 10:22 am
It will probably be a heater flap motor. The temperature one is pretty active most of the time, try changing the temperature when its doing it - or not doing it. If its not that could be another flap motor stacking.
caprixpack
Re: Buzzing noise
Post by caprixpack » Fri Apr 06, 2018 10:24 am
OK cheers I'll give it a go next time I'm out in it.
dirtydirtydiesel
Re: Buzzing noise
Post by dirtydirtydiesel » Sat Apr 07, 2018 11:36 pm
It's easy to check the flap, pop out the pollen filter & whilst looking down the hole under the pollen filter aperture
Get a assistant to press the recirculate button you should see the flap open & close if all is well.
Obviously with the ignition on.
frog
Re: Buzzing noise
Post by frog » Mon Apr 09, 2018 7:05 am
And engine must be running 8)
The recirculation flap motor is not operated for this long, at most ~ 10-20 seconds... Probably it's a temperature flap motor as PeterN suggests. Also because you hear it from the middle of the dash, that is where they are. There are two of these temperature flap motors:
Heater detail
(203.79 KiB) Not downloaded yet
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
