Roof Console
zubby
Roof Console
Post by zubby » Wed Jan 17, 2018 1:34 am
hey guys . looking for a sunroof console housing complete... will also pay shipping...
This type ...Pug 406
dirtydirtydiesel
Re: Roof Console
Post by dirtydirtydiesel » Wed Jan 17, 2018 8:58 pm
If no one on here helps, try posting on the 406 farcebook page :roll:
zubby
Re: Roof Console
Post by zubby » Wed Jan 17, 2018 10:04 pm
Been there done that... may have to use a tire iron next. not even fish bros could find it
zubby
Re: Roof Console
Post by zubby » Wed Jan 17, 2018 10:10 pm
BTW getting a fault code p0341 and p0410 ..camshaft position sensor 'A" circuit range and secondary air injection system..how do I fix these? Please and Thanks.
Re: Roof Console
Post by GingerMagic » Thu Jan 18, 2018 12:02 am
Hi Zubby.
Just to say that only sunroof equipped cars have that centre light set up ( I don't mean the switch part, the whole thing is smaller... ) so limited parts available I should imagine.
I'll check my shed as my old donor car had a sunroof - I may still have that in a box.
As for the fault codes, clear them and see what comes back - the cam sensor is needed to start the engine (it talks with the crank sensor to make sure everything is lined up and spinning fast before telling the ECU to fire the injectors )
If it fails then the car won't start, so it's with old fault or a dodgy wire under the fuel rail.....
Not sure about the other code - depends if you are diesel or petrol.
1999 T4 family wagon
2005 Vauxhall Meriva
PeterN
Re: Roof Console
Post by PeterN » Thu Jan 18, 2018 10:42 am
I will check my scrap one, although from memory it looks different to that, its a '51 reg.
Re: Roof Console
Post by steve_earwig » Thu Jan 18, 2018 11:46 am
zubby's profile page wrote:Car model/trim level:
1.8 16V 4AT (112HP)
:wink:
Re: Roof Console
Post by GingerMagic » Thu Jan 18, 2018 1:33 pm
1.8 16V 4AT (112HP)
:wink:
Doh.. :oops:
Won't be the MAF then.....
zubby
Re: Roof Console
Post by zubby » Fri Jan 19, 2018 11:47 am
No not the MAF. 8)
Re: Roof Console
Post by GingerMagic » Fri Jan 19, 2018 5:45 pm
I've got one, just dug it out of my shed....
It does look different to yours as my buttons are not the same - this one is from a 2004 exec.
Maybe you can post a picture of the back of yours and I'll check the connections are the same.
dirtydirtydiesel
Re: Roof Console
Post by dirtydirtydiesel » Fri Jan 19, 2018 6:47 pm
406 forum to the rescue agian 8)
zubby
Re: Roof Console
Post by zubby » Sat Jan 20, 2018 3:40 am
Will do that in a bit.... Post a pic of yours..
