Wanted cruise control stalk
blackblade58
Post by blackblade58 »
Just need the final piece of the puzzle now to complete my cruise control retrofit, as title states I need the stalk and lower steering wheel cowl if anyone has one, it's for a 2001 diesel estate, 90hp.
Thanks.
ruwds
Re: Wanted cruise control stalk
Post by ruwds »
The lower cowl that comes with the car might have a slight outline on it where the opening should be and can be cut off to create the opening. That's what I did on mine, followed the outline and made the opening.
Newer stalks from 307 etc are also told to be suitable with the 406.
EDIT: Just realised yours is 2001 and must be a semi mux? Then the stalk will be different. It might be different with the lower cowl as well. Mine is a 2003.
2003 406 2.0 HDi 90 S
• Connects2 USB/SD/Aux • Cruise Control
blackblade58
Thanks for that, I have looked at my cowl and I can cut it out, I just really need the stalk. I have found one for an early petrol 406 coupe, it looks similar but I can't get a definitive answer as to whether it's suitable for mine, the seller is not really helping either, I just need a part number or some better pictures.
Thick stalk or skinny stalk?
1999 T4 family wagon
2005 Vauxhall Meriva
blackblade58
Skinny stalk with the white 5 pin plug please.
I may have one available soon - I've been offered a really really tatty 406 executive estate, 2001 - for £80.
If I get it I'll let you know.
blackblade58
Sounds great, thanks. I will buy the whole car if you don't have it but yeah let me know. Many thanks.
GingerMagic wrote:I may have one available soon - I've been offered a really really tatty 406 executive estate, 2001 - for £80.
That's the spirit!
My bro has a 'new' 53-plate 110 exec estate and the possibility of harvesting bits from his 2.2 exec that's lying in a field in France......
(Sorry for the thread hijack bb58). :oops:
blackblade58
That sounds good as well, thanks.
Where are you based?
I'm happy to remove all the pieces you need to fit CC to your car, and post it off to you - once I get this car maybe next week?
Edit: just found this on eBay - bargain..!!
http://www.ebay.co.uk/itm/PEUGEOT-406-C ... SwV0RZivvM
blackblade58
I'm in Somerset. I have seen that on eBay but he won't send me any better pictures of the wiring or the part number label so I don't know for sure if it will fit, there is a good chance it will because it has the 5 pin plug on the end, what do you think?
