tyre squeeling ????
johntl
tyre squeeling ????
Post by johntl » Sat Apr 15, 2017 4:33 pm
Hi ,any ideas ????
over the last month my n/s front tyre when cornering has started to squeel, just now and again even at low speeds, the history of the tyre is its my spare tyre I have never used in the 7 yrs I have had the car, I'am just using it till the other side wears down and I will replace both, Its a pirrelli p6000 10 yrs old !!!but looks ok ,but do think due to age causing problem?? been on car about 2 month without probs
Re: tyre squeeling ????
Post by GingerMagic » Sat Apr 15, 2017 5:24 pm
Tyres do have a shelf life, and if it's been in your boot for 7 years then it could do with replacing.
I would be tempted to put the OSF in the boot as it has a bit of life in it, and replace both fronts, if you are able to afford it.
1999 T4 family wagon
2005 Vauxhall Meriva
Post by Welly » Tue Apr 18, 2017 7:48 am
Rubber just aint Rubber anymore :frown:
Your spare tyre has likely 'gone off' as it were.
johntl
Post by johntl » Mon May 01, 2017 5:55 pm
cheers guys, now fitted two new pirelli's , job sorted!
