seat replacement
bronc
seat replacement
Post by bronc » Mon Feb 01, 2016 12:29 pm
Hi, The seats in my 406 estate are really grubby and I have been offered a full set of seats, but the front two have the electric controls whilst mine are just ordinary manual. I have looked at the articles here and it does sound a bit complicated, especially the driver's seat If I get bogged down is it possible to do away with the electric gizzmoes and just fit the new seats onto the old runners. The seats are too good to pass up! Thanks Bronc
benczuk
Re: seat replacement
Post by benczuk » Mon Feb 01, 2016 1:50 pm
Hi,
You can't remove the electronics as you will lose the ability to adjust them.
I think i read somewhere that all models had the wiring in place for them, but I could be wrong.
If there inst wiring in place all you need is a 12v feed (red wires in plug) and an earth (brown wires in plug) connected up to the yellow plug under the seat.
Post by GingerMagic » Mon Feb 01, 2016 7:38 pm
Hi, on a friends LX model the only wires present were for the airbags, so we removed the covers from my electric seats and fitted them instead - it looks a right dogs-dinner but better than nothing...
Seat covers from Hellfords may be a better option :wink:
1999 T4 family wagon
2005 Vauxhall Meriva
Post by steve_earwig » Mon Feb 01, 2016 7:45 pm
Hi there. It's only a problem if the driver's seat has a memory (ecu under the seat, big connectors and an extra button behind the seat controls) If not then its pretty straight forward, you may or may not have wiring but people generally rob 12 volts from the fag lighter. If it has memory then it's a lot more complex but still do-able.
PeterN
Post by PeterN » Tue Feb 02, 2016 12:48 pm
The car I just bought was a GLX supposedly with electric seats, the passenger seat was but the driving seat was a manual one from a later car. I have now obtained and fitted electric seats and they work fine, not heated though, all the relative plugs and wiring were under the carpet except the airbag ones which were connected to the old seat, I just plugged then in and away they went.
On the C5 the wiring was all there under the carpet when I fitted electric seats but I don't think it is on the 406.
damo2612
Post by damo2612 » Sat Feb 27, 2016 5:44 pm
Hi guys, can anyone give me some advice. I have a d8 coupe that has manual cloth seats, I have side airbags and pre tensioners, I have purchased a full leather interior with heated memory electric front seats, I also have the ecu coming (all from a d9). My d8 has two extra plugs which go into blanks, one brown and other is yellow. Will they be for powering elec seats??
PeterN
Post by PeterN » Mon Feb 29, 2016 3:37 pm
Probably, the will be much thicker than the other leads if the do.
Post by GingerMagic » Mon Feb 29, 2016 5:13 pm
On a D9, the yellow is power and the brown is heated seats...... - not sure about D8 though.
damo2612
Post by damo2612 » Mon Feb 29, 2016 7:19 pm
That's great guys, thanks for your help.
damo2612
Post by damo2612 » Tue Mar 01, 2016 8:57 am
I've tried to fit the passenger seat, put yellow plug into yellow and same with brown, no power?? I have the seat fuses in the fuse box and the heat fuse is in situ under the bonnet? I may have to cut the yellow and brown plugs from my d8 loom and solder them to some cable and run it from the fuse box. Just had the ecu delivered, they have hacked the loom from the car. Is it best to unravel the loom and bin what doesn't go to ecu? I'm no electrician but I'm willing to give it a go.
damo2612
Post by damo2612 » Thu Mar 03, 2016 10:11 am
Hi guys, I have just found and brought a converted ecu that allows you to fit electric heated seats in any 406. I'm hoping I can see which wires have been used to be able to make it possible. If alls well I will let you all know how.
