oil gathering (around HDi injectors)
Knowledge Base Articles
Locked
dave406
Post by dave406 »
Hi all
I seem to have the same p#issue as everyone else oil on top of the engine cleaned it all up and after 17 miles is back to looking ike this>?
(this was taken pre clean so its a little tider)
Any ideaS?
fattail95
Re: oil gathering
Post by fattail95 »
I'm fairly sure I know what's going on here. I'm assuming the injector pictured is the one nearest the intercooler pipe? On earlier HDi 110's, the intercooler pipe incorporated an air doser (butterfly valve essentially) which opens/closes depending on how my EGR is required. This will create a small vacuum in the manifold and forces exhaust gasses to be recirculated, preventing clean air entering the intake. This air doser commonly leaks, meaning any oil residue in the intercooler pipework will drip out and settle in that little indentation near injector 4 (or 1?). My car had this issue, and I simply replaced the metal 90deg bend with one from later cars. See below:
Disabling the EGR with a blanking plate and removing the air doser unit altogether and replacing with the pipework from a later car (easy job) is the best solution. You'll also see more power and better mpg, as well as knowing your engine is no longer sucking in dirty exhaust gases.
Hope that helps!
dave406
Re: oil gathering
Post by dave406 »
How to you bypass the sensor that does the air doses
fattail95
Re: oil gathering
Post by fattail95 »
To remove the EGR and air doser, you need to both install a blanking plate and plug the vacuum supply to the EGR electrovalve. These EV's are mounted on the bulkhead, on the 110 there are 3 - the one you're after is the one with the blue plug. Locate the vacuum line going into it from the vacuum pump, and plug it with a suitable screw/bolt ensuring it's a tight seal to prevent any air leaks.
Next, remove the 90deg elbow and replace it with one from a later car (pictured in my last post), there are two bolts which hold it onto the intake manifold and it's at that join where the EGR pipe enters the intake manifold, so while replacing it you may as well install the blanking plate (use some high temp liquid gasket to prevent boost leaks). Plug the vacuum line that used to go to the air doser and that finishes the install!
If you decide not to remap the car with a no-EGR map, you'll find a dormant code stored on the ECU (which wont trigger an EML) saying "air flow higher than expected". Just ignore it :)
dave406
Re: oil gathering
Post by dave406 »
Can this all be done from above the car
fattail95
Re: oil gathering
Post by fattail95 »
Yup and very easily! It sounds a bit complicated but it really isn't, if I can do it I'm sure you can too! :) The only tricky but is the bolts (well studs, technically) that hold the elbow onto the intake manifold. Access is a little tight so be careful not to drop anything (like I did :oops: ) as you'll have to take a trip to the dealer for new ones!
fattail95
Re: oil gathering
Post by fattail95 »
This diagram shows the back of the intake manifold as well as the elbow that's attached. The EGR pipe joins just at the seam.
dave406
Re: oil gathering
Post by dave406 »
With you now
dave406
Re: oil gathering
Post by dave406 »
Is it just the elbow that's different or will the rubber hose be different aswell
fattail95
Re: oil gathering
Post by fattail95 »
Rubber hose is identical, just the elbow that's different.
dave406
Re: oil gathering
Post by dave406 »
Same on Picasso and c5? Also can it be a 90 or a 110
Locked
