Polishing and waxing
Whether you're just washing the car, into detailing in a big way or enhancing your 406, collect and share hints and tips here.
rwb
Post by rwb » Sun Dec 29, 2013 11:32 am
This is really a question for waxman: which of your products do I need and where can I buy them?
I'm thinking of claying, polishing, and waxing.
I have access to a machine polisher. Is it true that hand polishing is pointless because the top paint layer (clear coat is it) is so hard?
I think I want a hard wax that will last a long time as this won't be a regular thing!
My main objectives are to protect the paintwork and improve the appearance of swirl marks.
Point me in the right direction!
R-plate 406 1.9 TD LX (1 year) | 02 406 2.0 HDi (90, Siemens) GLX+nav (8 years) | 07 407 2.2 HDi GT (since 2013) | 508 2.0 140 SR | Map of PeugeotForums users offering PP2k
Re: Polishing and waxing
Post by Welly » Fri Jan 03, 2014 1:48 pm
It's normally recommended to get yourself a scrap body panel to practice on before you go nuts with a machine, you can 'scorch' the clear coat if you don't wet the surface right or spend too long in one area etc.
I use Meguires stuff but applied manually; first clay bar with plenty of clay lube (quick detailer), then a Paint Cleaner applied and buffed off, then a Polish applied and buffed and finally a Carnuba Wax. I know for sure there are better, more exclusive, products available and in particular the final Wax coating but I find the Megs stuff very easy to use and with great results.
Now I've finally got my car back in the garage after 4-days of sorting and many runs to the Council Tip I might build up my collection of stuff a bit and experiment with new products. I've sorted myself a car detailing cupboard and bench space :cheesy:
I hope Waxman can give further help as I'll be interested too.
2005 Volvo S40 T5 a bit pampered, taking bookings from nice* VAG owners
dave406
Post by dave406 » Fri Jan 03, 2014 5:59 pm
Hi RWB
This is my process all by hand (saying for a machine polisher)
Wash with meg's mitt AG shampoo and 2 bucket method + brushes for gaps
Clay (sonus green)
Wheels with AG wheel cleaner
Polish with AG super resin polish
wax with colli 476 ( 3 coats)
Alloy wheel seal
Tyre dressing
Windows
plastics
dave406
Post by dave406 » Fri Jan 03, 2014 6:00 pm
Check out http://www.cleanyourcar.co.uk/forum/ and detailingworld.com
Waxman
Post by Waxman » Thu Jan 16, 2014 12:29 am
Hi rwb,
Sorry just caught this thread :wink:
dave406 has indeed a good wash method. The brushes for the 'nooks and crannies' are ideal for getting around the exterior tightwork - If you need some of these, let me know as I'm an authorised distributor for a very well know / respected manufacturer of these. :wink:
If you are looking at swirl removal, indeed as has been mentioned in this thread, it's 'possible' to remove an element by hand but takes a verrrry long time.
If you have access to a machine polisher, then certainly get a test panel first to hone the practice on before going 'straight to paint' as such.
ok, without a machine polisher :
In all ways, the best method to get the paint in good condition, is thorough decontamination via way of clay and or fallout/tar removers.
Single clay can be used, I'd recommend a 'soft clay' i.e something sold by Bilt Hamber - this is around the £10/12 mark delivered and will last you a couple of years ( you break the block into 4 pieces, using 1 piece at a time ) - Water can be used as lube for this clay but I prefer a very mild ration mix of car shampoo in a spray bottle - something like a 1:10 rate will be fine.
You'll find areas like the lower doors, arches and rear of car that picks up most contaminants as well as flat panels - roof/bonnet etc.
Usually to fully clay a car that has not been clayed before can take 2/3 hours depending on how bad it is. you will also find that by doing this you may notice more defects/marks in the paint - of course this is because your taken the paint back to it's 'bare' condition.
Once you have clayed this will leave the paintwork in a smooth condition.
At this stage you'll have a few options. - If you have not got the time to machine polish, then after you have rinsed and dried the car down, you can use a glaze/polish/filler to 'hide' the swirls - something like Autoglym Super Resin polish can be used for this.
Once you have done this, then add a few layers of decent wax to 'lock down' the work you have done. - Obviously as the paint has not been corrected, then after a while those swirls will start to re-appear - then you can repeat the process (without clay) - although I'd recommend claying at least once a year.
Machine polishing is not hard itself, what needs to be considered is the speeds/pads and compounds. These are the make or break of a good machine polish. Never start with an aggressive combination i.e heavy cutting pad and heavy cutting compound. - It's best to work a light combination and move up if necessary.
Machine Polishing removes swirls with the pad/compound as it generates the heat and cut necessary to remove the microns of damaged clearcoat. - This is why you have to be careful - too heavy a method, too ,much pressure or leaving the pad at a high speed in a single area can cause paint damage commonly known as strikethrough. It's where the clearcoat has been removed leaving the paint layer visible - The repair for this is basically a pro respray.
If you want to learn how to use a machine polisher- there are a few good ways of learning - The 'Junkman' videos are a very good resource i.e heres a part one vid - ( he has a lot of other videos, that will help ) - An Ex Marine and a bit nutty but he explains things in good tutorials - Great guy :wink:
With regards to my waxes, then they can be bought at many resellers in the UK - However as part of this specific forum and to it's members I'm offering them at a reduced lower price.
For example - 'Fortify' which is a 100ml pot is a winter wax built for durability with very good resistance to road grimes and salts - retails at £24.95 + delivery. I could offer that at £20 delivered to 406oc members. - You can have a look at my different waxes available by checking out: http://www.propa-protection.com/wax.htm - Each wax has been fully researched, developed and tested and only feature the highest class ingredients available.
I'll certainly put a 406oc Members only price list together on here soon.
Let me know if any more Q's - Of course glad to help. :)
Jay
The Rubble Shifter: 2.0 HDi 110 GTX 406 Estate, Tuning Box, K&N Filters.
Thunderbird 4: Mercedes AMG E55, Full Decat & Res Delete.
*New Addition* The Roller Skate: VW Polo GTi
jonsowman
Post by jonsowman » Thu Jan 16, 2014 10:36 am
Just wanted to say thanks for taking the time to put that together, very helpful and interesting! No excuse not to polish and wax my car now :cheesy:
rwb
Post by rwb » Sun Jan 19, 2014 10:43 pm
Shopping list:
* 2 buckets, both with grit guards
* wash mitt
* shampoo
* microfibre cloths for wiping off water spots/marks and buffing http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0214924538
* soft clay http://www.ebay.co.uk/itm/261267441372
* lube for clay http://www.ebay.co.uk/itm/271072441451
(There's no point me trying to polish; it won't end well.)
* wax viewtopic.php?f=7&t=21550
* wax applicator pads http://www.ebay.co.uk/itm/261191309723
Waxman
Post by Waxman » Mon Jan 20, 2014 1:00 pm
have a look at this clay :wink: - No need to buy a seperate clay lube for this, just use a dab of car shampoo & water in a normal spray bottle:
http://www.ebay.co.uk/itm/Bilt-Hamber-A ... 2a2e0a669b
