EDITECU - 10% discount on remaps of all kinds
wasp
Re: EDITECU - 10% discount on remaps of all kinds
Post by wasp » Thu Feb 07, 2013 11:39 pm
I wonder if they can boost the performance of my 307 estate, 1.4 hdi... 0-60 16.3 secs...even longer if i have the shopping & the dog in the boot! 0-100 N/A (official figure) ....top speed 97mph :(
i guess ill have to give santa pod a miss this year.
mpg>bhp...... pfff!
"A HDI Is For Life and NOT Just For Xmas!!!"
Post by Doggy » Fri Feb 08, 2013 12:05 am
Guess you'll not be retro fitting cruise to that fireball then?
wasp wrote:mpg>bhp...... pfff!
Awesome 8)
OdinEidolon
Post by OdinEidolon » Fri Feb 08, 2013 9:07 am
wasp wrote:I wonder if they can boost the performance of my 307 estate, 1.4 hdi... 0-60 16.3 secs...even longer if i have the shopping & the dog in the boot! 0-100 N/A (official figure) ....top speed 97mph :(
mpg>bhp...... pfff!
Very easy if you have a Bosch EDC16. But your car can also have a Siemens Sid801 which is more difficult. Can you check for labels around the ECU or ECU box?
Frenzy406
Post by Frenzy406 » Mon Apr 01, 2013 2:13 am
Hi there, I have the 180 map on my 2.2 Hdi. 2003 Estate.
I was very happy with it for a couple of weeks but soon got bored, so i started bleeding some boost signal to the map sensor to increase the boost ( very basic I know :oops: , but it increased driving fun ) from 1.3 bar, gradually to 1.8 bar ( after first fitting a very large FMIC poking out of the front of the car ! ), until it started dropping into limp mode too often.
I do not know what power/touque i was getting, but Obviously the 1.8 bar did give a considerable power & torque increase above the 180 to satisfy me for about a month, until it wrecked my turbo.
I replaced with another standard turbo and only increased the boost to 1.5 bar, which i think allowed the turbo to live for about a year longer.
My car is now off the road waiting for a bigger turbo and possibly a new map?
So my questions are :
1) What would be the highest power / torque levels you would be able to / wish to supply for this engine? (considering that when i squeezed 1.8 bar thru the engine, the increase was quite noticeable, but as it is never enough, i want to push the limits )
2) I have a T28 Wastegated turbo to try out, do you have any opinion/advise on this?
3) What other modifications would you recommend to gain more power ( eg details of injectors, pump, internals etc?)
4) I am also considering upgrading to a 6 gear 'box, would this have implications for a remap or could i do that at anytime before/after?
Kind regards, Neil :D
406 2.2Hdi200+Bhp7SeatEst,De-Cat+Fap+StraightThru+6x3"SS B/Box,De-Badge+Trim+R/Wiper+RoofBar(CF Fills),StrutBrace,19"s,LOW-120Fr-80Rr,300lb F/Springs,AdjKonis,Bilsteins,CustomStrutTopMounts,EBCslotDiscs
+FerodoRacePads,Raised Bonnet,AdjRearARB kit,BoostGuage,JAPSPEEDscoobyFMIC,T28
To Do>6-Speed,CF Panels,WindowTints
But that's just me :)
Frenzy406
Post by Frenzy406 » Mon Apr 01, 2013 2:21 am
Hi there, I have the 180 map on my 2.2 Hdi. 2003 Estate, with straight through de-cat de-fap 2.5" system.
I'm not sure exactly what power /touque i was getting, but Obviously the 1.8 bar did give a considerable power & torque increase above the 180 ( would estimate at least 200ish bhp) to satisfy me for about a month, until it wrecked my turbo.
My car is now off the road waiting for a bigger turbo and theoretically a new map?
2) I have a T28 Wastegated turbo to try out, do you have any opinion/advise on this, or suggestion of a different bigger turbo to use?
OdinEidolon
Post by OdinEidolon » Mon Apr 01, 2013 10:38 am
Frenzy406 wrote:Hi there, I have the 180 map on my 2.2 Hdi. 2003 Estate, with straight through de-cat de-fap 2.5" system.
Hi, I'll reply point by point:
1) I'd say 200hp / 450Nm are what you can get with the standard turbo if you upgrade it correctly. With better turbo you could see more (220hp / 500NM?) but... really this is on the limit, your clutch will last a week...
With the standard turbo in the standard form 180hp / 430Nm are what you can aim for. That's a whole lot more than the so-called "180" map available from the internet, and it's also much more funny to drive.
2) Sorry, we've never used that utrbo in the past, you have to ask a turbo specialist about wether it'll work / fit. Then linearizing the maps can be done, but remember it's a PITA to do so => expensive.
3) other than turbo... Pump and HP sensor first. Then injectors. But definitely pump first. There are some BMW umps that should fit more or less... I heard of someone doing that, but I never saw it on the net or in person.
4) You can do it anytime. There are some small adjustements that can be made in the map but they are not major and not strictly necessary, it's fine.
Busman
Post by Busman » Mon Apr 01, 2013 11:04 am
Which has got me thinking that these cars are getting so cheap now that it's more economicaly possible to experiment a bit more....
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
OdinEidolon
Post by OdinEidolon » Mon Apr 01, 2013 12:15 pm
Busman wrote:Which has got me thinking that these cars are getting so cheap now that it's more economicaly possible to experiment a bit more....
The car is relatively cheap in the UK, but turbos and turbo fitting isn't, sadly!
kevinday284
Post by kevinday284 » Sun Apr 21, 2013 3:50 pm
Hi
I have a 406 2.0 hdi 90bhp the aa said my ecu has a problem my car will not start im get power thou to the glow plug relay but when u turn the key on power is going to relay but not coming out to the glow plugs I've changed the relay already and the A said it could be the ecu how can I check this or how much will it cost to send it to you guys for checking the ecu is a Siemems part no 9646801180 or 5ws40024F-T it has 3 plugs on top .
many thanks for taking your time to read this
OdinEidolon
Post by OdinEidolon » Mon Apr 22, 2013 9:46 am
kevinday284 wrote:Hi
Hi, yes we could fix it up if the ECU's at fault. Would you please give me your address so I can estimate the cost of shipping back?
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Jul 09, 2013 11:37 pm
Hi'
I have a very good condition 406 110 hdi, it's done 79 thou with full service history & fully sinth oil every 6 thou, my question is what power upgrades can you offer me,
bearing in mind I am looking at de-cating, full st/st 65mm exhaust, better intake / air filter ass, de-egr'ing & air dosser & a big fmic :cheesy:
Look forward to your reply Paul.
OdinEidolon
Post by OdinEidolon » Wed Jul 10, 2013 8:15 am
dirtydirtydiesel wrote:Hi'
Depends on which ECU you have. Do you have the Bosch or the Siemens? The Bosch is very easy to deal with, the Siemens more difficult and will require you to remove the ECU from the car to read it.
dirtydirtydiesel
Post by dirtydirtydiesel » Wed Jul 10, 2013 7:44 pm
Sorry :oops: Bosch :cheesy:
OdinEidolon
Post by OdinEidolon » Wed Jul 10, 2013 8:23 pm
Well then you're going for 150hp, above that you have to start minding the clutch tho. Unfortunately we are actually closed and on vacation now, so for a more complete answer you'll have to wait a few days. By the 25th iirc we'll be operative again. If you can send me a reminder around that date I'll make sure we get you an approximate quote and power/torque numbers.
dirtydirtydiesel
Post by dirtydirtydiesel » Wed Jul 10, 2013 8:53 pm
No worries, Thanks for that I'm just testing the water at the mo, will be ready in the next month or so :P
